Z axis issue
My Z axis became stiff and very noisy.
Its hard to move by hand and makes the same noise as it is at the end of the frame.
Other axis are OK.
What could be wrong?
Thanks
m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
Board ID: 08DLM-996AL-K65SJ-6J1F6-3S86P-KV0LY
Used output buffers: 1 of 24 (13 max)
Static ram: 25712
Dynamic ram: 93160 of which 0 recycled
Exception stack ram used: 360
Never used ram: 11840
Tasks: NETWORK(ready,752) HEAT(blocked,1232) MAIN(running,3800) IDLE(ready,160)
Owned mutexes:
Last reset 02:29:36 ago, cause: power up
Last software reset at 2020-11-04 10:14, reason: User, spinning module GCodes, available RAM 11764 bytes (slot 2)
Error status: 0
Free file entries: 10
MCU temperature: min 29.6, current 38.7, max 39.4
Supply voltage: min 12.7, current 12.8, max 12.9, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2020-11-11 22:09:23
Slowest loop: 4.88ms; fastest: 0.06ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 159, MaxWait: 8766429ms
=== DDARing ===
Scheduled moves: 11, completed moves: 11, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.54ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.23
WiFi MAC address 98:f4:ab:dc:26:38
WiFi Vcc 3.39, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 25592
WiFi IP address 192.168.68.113
WiFi signal strength -70dBm, reconnections 0, sleep mode modem
M906
Motor current (mA) - X:800, Y:800, Z:800, E:1000, idle factor 50% - WiFi -
always post your config.g
but it sounds like a mechanical issue.
check each moving part that it can move on its own.
maybe grease/oil the bearings. -
What type of printer is this? Describe your z axis.
@Veti I greased and reassembled the axis
And it looks OK now10x
