    RRF and Heaters – Duet 2 WIFI 3.1.1
    1.7k
    • MJCTundefined
      MJCT @Veti
      @Veti Sorry , I meant to say M303 not M307
      Vetiundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti @MJCT
        @MJCT
        yes you run M303 and put the values into the config with M307.
        i understood what you meant.
        MJCTundefined 1 Reply Last reply Reply Quote 0
        • MJCTundefined
          MJCT @Veti
          @Veti After both tests and M500's got this
          ; config-override.g file generated in response to M500 at 2020-11-13 11:54
          ; Heater model parameters
          M307 H0 A135.2 C635.5 D0.6 S1.00 V23.6 B0
          M307 H1 A600.5 C163.9 D10.4 S1.00 V24.0 B0
          ; Workplace coordinates
          G10 L2 P1 X0.00 Y0.00 Z0.00
          G10 L2 P2 X0.00 Y0.00 Z0.00
          G10 L2 P3 X0.00 Y0.00 Z0.00
          G10 L2 P4 X0.00 Y0.00 Z0.00
          G10 L2 P5 X0.00 Y0.00 Z0.00
          G10 L2 P6 X0.00 Y0.00 Z0.00
          G10 L2 P7 X0.00 Y0.00 Z0.00
          G10 L2 P8 X0.00 Y0.00 Z0.00
          G10 L2 P9 X0.00 Y0.00 Z0.00
          do I need to add any M501 at config-override or at config.g?
          • Vetiundefined
            Veti @MJCT
            @MJCT said in RRF and Heaters – Duet 2 WIFI 3.1.1:
            at the end of config.g
            • MJCTundefined
              MJCT @Veti
              @Veti Just like this?
              M501
              • Vetiundefined
                Veti @MJCT
                @MJCT
                thats you config-overwrite not your config
                • MJCTundefined
                  MJCT @Veti
                  @Veti Sorry
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                  M143 H0 S110 ; set temperature limit for heater 0 to 110C
                  M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
                  M140 H1 ; map heated bed to heater 0
                  M143 H1 S290 ; set temperature limit for heater 0 to 110C
                  M563 P0 S"Extr 1" D0 H1 F0 ; define tool 0
                  T0 ; select first tool
                  M501
                  • Vetiundefined
                    Veti @MJCT
                    @MJCT
                    yes
                    MJCTundefined 1 Reply Last reply Reply Quote 1
                    • MJCTundefined
                      MJCT @Veti
                      @Veti And another problem arises.
                      On my touch screen I’m only getting readings for temperature under the “bed Icon”, nothing appears bellow the “nozzle icon”.
                      Web interface shows readings both for extruder 1 and bed. When I request the temperature to rise in one of them, they both show the same target temperature but only the extruder 1 curve moves up
                      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Nov 12 2020 15:24:07 GMT+0000 (Hora padrão da Europa Ocidental)
                      M550 P"AA 300x300x600" ; set printer name
                      M669 K1 ; select CoreXY mode
                      M551 P"AA" ; set password
                      M552 S1 ; enable network
                      M586 P0 S1 ; enable HTTP
                      M586 P1 S0 ; disable FTP
                      M586 P2 S0 ; disable Telnet
                      M569 P3 S0 ; physical drive 3 goes backwards
                      M92 X80.00 Y80.00 Z400.00 E98.50 ; set steps per mm
                      M566 X950.00 Y950.00 Z30.00 E3000.00 ; set maximum instantaneous speed changes (mm/min)
                      M203 X6000.00 Y6000.00 Z1000.00 E3300.00 ; set maximum speeds (mm/min)
                      M201 X3100.00 Y3100.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
                      M906 X1850 Y1850 Z1750 E1750 I30 ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30 ; Set idle timeout
                      M208 X10 Y10 Z0 S1 ; set axis minima
                      M208 X300 Y300 Z570 S0 ; set axis maxima
                      M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
                      M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
                      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                      M558 P9 C"^zprobe.in" H5 F120 T10000 ; set Z probe type to bltouch and the dive height + speeds
                      G31 P25 X24 Y0 Z2.425 ; set Z probe trigger value, offset and trigger height (quanto mais elevado Z, mais proximo da mesa)
                      M557 X50:250 Y50:250 S25 ; define mesh grid
                      M501
                      • Vetiundefined
                        Veti
                        what firmware are you running on the paneldue?
                        • MJCTundefined
                          MJCT @Veti
                          @Veti 1.24
                          • MJCTundefined
                            MJCT
                            Under "Heat" is it every thing normal?
                            M122
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                            Board ID: 08DJM-9178L-L4MSJ-6J9F0-3S46Q-KT3YP
                            Used output buffers: 3 of 24 (13 max)
                            Static ram: 27980
                            Dynamic ram: 93884 of which 60 recycled
                            Exception stack ram used: 304
                            Never used ram: 8844
                            Tasks: NETWORK(ready,308) HEAT(blocked,1224) MAIN(running,1880) IDLE(ready,80)
                            Owned mutexes: WiFi(NETWORK)
                            Last reset 00:21:42 ago, cause: power up
                            Last software reset at 2020-11-13 12:09, reason: User, spinning module GCodes, available RAM 8836 bytes (slot 0)
                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                            Error status: 0
                            MCU temperature: min 43.0, current 49.1, max 49.4
                            Supply voltage: min 23.7, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                            Date/time: 2020-11-13 13:30:55
                            Cache data hit count 2136812117
                            Slowest loop: 13.47ms; fastest: 0.14ms
                            === Storage ===
                            Free file entries: 10
                            SD card longest read time 4.1ms, write time 6.0ms, max retries 0
                            Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                            === MainDDARing ===
                            Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                            === AuxDDARing ===
                            Bed heaters = 1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
                            Heater 1 is on, I-accum = 0.2
                            Segments left: 0
                            Movement lock held by null
                            HTTP is idle in state(s) 0
                            Telnet is idle in state(s) 0
                            File is idle in state(s) 0
                            USB is idle in state(s) 0
                            Aux is idle in state(s) 0
                            Trigger is idle in state(s) 0
                            Queue is idle in state(s) 0
                            Daemon is idle in state(s) 0
                            Code queue is empty.
                            === Network ===
                            Slowest loop: 26.07ms; fastest: 0.00ms
                            HTTP sessions: 1 of 8
                            • WiFi -
                              Network state is active
                              WiFi firmware version 1.23
                              WiFi MAC address ec:fa:bc:01:d4:c6
                              WiFi Vcc 3.38, reset reason Unknown
                              WiFi flash size 4194304, free heap 24528
                              WiFi IP address 192.168.10.62
                              WiFi signal strength -54dBm, reconnections 0, sleep mode modem
                            • Vetiundefined
                              Veti
                              i dont see anything unusual. maybe someone else can have a look?
                              • MJCTundefined
                                MJCT @Veti
                                @Veti Funny
                                Just deleted the 2 lines that I added manually to the config (M140 and M143) and everything went back to normal
                                How can this be?
                                • MJCTundefined
                                  MJCT
                                  Adding M143 H1 S290 and everything stays normal
                                  Adding M140 H1and everything gets broken again
                                  This M140 H1 command for the nozle makes all the difference
                                  • Vetiundefined
                                    Veti @MJCT
                                    @MJCT
                                    that makes sense.
                                    this means that the heater is designated to be a bed heater.
                                    you dont want to do that for H1, as it is not a bed heater.
                                    • MJCTundefined
                                      MJCT @Veti
                                      @Veti that said, don't I need to map it anyway with some other M140?
                                      I just leave it like that?
                                      • Vetiundefined
                                        Veti @MJCT
                                        @MJCT
                                        yes
                                        • MJCTundefined
                                          MJCT @Veti
                                          @Veti Ok, thank you very much for all this hours that you spent helping me
