Single Z-Motor doesn't move
  • Hi,
    I have a stepper motor connect to Drive 2, together with two jumpers at the ZB position. However, the motor doesn't rotate when I give a commant via the webControl. The tool position and speed in the webControl dashboard do change. I also have connected the motor to the drive 4 (M584 X0 Y1 Z4 E3 in config file below) and than it does work. The same type stepper motors connected to X and Y work fine as well. The Z-motor is not connected to a spindle yet, so the load is zero.
    I have checked the resistance over the ZB jumpers, which is non.
    Anyone an idea what could be wrong?
    The config file is as follow:
    ; generated by RepRapFirmware Configuration Tool v2.1.4 on Sat Dec 14 2019 22:55:43 GMT+0100 (Midden-Europese standaardtijd)
    G90                                     ; send absolute coordinates...
    M83                                     ; ...but relative extruder moves
    M550 P"My Printer"                      ; set printer name
    M552 S1                                 ; enable network
    M586 P0 S1                              ; enable HTTP
    M586 P1 S0                              ; disable FTP
    M586 P2 S0                              ; disable Telnet
    M569 P0 S1                              ; physical drive 0 goes forwards
    M569 P1 S1                              ; physical drive 1 goes forwards
    M569 P2 S1                              ; physical drive 2 goes forwards
    M569 P3 S1                              ; physical drive 3 goes forwards
    M584 X0 Y1 Z2 E3                        ; set drive mapping
    M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
    M92 X800.00 Y800.00 Z800.00 E800.00     ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00     ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z20.00 E250.00     ; set accelerations (mm/s^2)
    M906 X1700 Y1700 Z1700 E1700 I30        ; set motor currents (mA) and motor idle factor in per cent
    M84 S30                                 ; Set idle timeout
    M208 X0 Y0 Z0 S1                        ; set axis minima
    M208 X380 Y330 Z230 S0                  ; set axis maxima
    M574 X0 Y0 Z0 S0                        ; set active low and disabled endstops
    M558 P0 H5 F120 T6000                   ; disable Z probe but set dive height, probe speed and travel speed
    M557 X20:360 Y20:310 S10                ; define mesh grid
    M305 P0 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 0
    M143 H0 S120                            ; set temperature limit for heater 0 to 120C
    M305 P1 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 1
    M143 H1 S280                            ; set temperature limit for heater 1 to 280C
    M106 P0 S0 I0 F500 H-1                  ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H1 T45               ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P2 S0 I0 F500 H-1                  ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M563 P0 D0 H1 F0                        ; define tool 0
    G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
    G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
    M122:
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later
    Board ID:
    Used output buffers: 3 of 24 (9 max)
    Static ram: 25712
    Dynamic ram: 93140 of which 0 recycled
    Exception stack ram used: 400
    Never used ram: 11820
    Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,3728) IDLE(ready,160)
    Owned mutexes:
    Last reset 00:17:31 ago, cause: power up
    Last software reset at 2020-11-13 19:01, reason: User, spinning module GCodes, available RAM 11820 bytes (slot 3)
    Error status: 0
    Free file entries: 10
    SD card longest block write time: 9.1ms, max retries 0
    MCU temperature: min 28.9, current 39.0, max 39.3
    Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: standstill, SG min/max 0/273
    Driver 1: standstill, SG min/max 0/288
    Driver 2: ok, SG min/max 0/0
    Driver 3: standstill, SG min/max 0/294
    Date/time: 2020-11-13 20:38:57
    Cache data hit count 3235876887
    Slowest loop: 12.37ms; fastest: 0.06ms
    Hiccups: 0, FreeDm: 160, MinFreeDm: 158, MaxWait: 801828ms
    === DDARing ===
    Scheduled moves: 19, completed moves: 19, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 29.61ms; fastest: 0.00ms
    HTTP sessions: 1 of 8
    Board: Duet WiFi 1.02 or later (duetwifi102)
    Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05 (2019-12-13b1)
    Duet WiFi Server Version: 1.23
  • Moderator
    Can you post a photo of how you have it wired?
    Do you get any error messages in the console when trying to move it?
  • There are no error messages in the console, the dashboard just shows the movement.
    Wiring: 4 stepper motors and 2 limit switches (X and Y)
  • @Eisbar have you tried moving a known working motor (either X or y) to z to rule out a motor/wiring issue?
  • @Eisbar this here looks very strange for me:
    at the Z driver right upper corner of the driver chip, can you make zoomed image please?
    As if the resistor is displaced.
  • Hope you can see it better on the picture below.
  • @jay_s_uk Yes I tried this as well. Than the motor also doesn't work, however all motors work fine at the other locations/drivers.
  • @Eisbar this looks ok, it was a matter of perspective.
  • @Eisbar please check the backside also, that the elements are soldered correctly, especially the connector socket of Z.
  • Moderator
    If you unplug the motor (while powered off) and then power up and try to move the motor does it give an error?
    When and where was the Duet purchased?
  • @Phaedrux there is no error with the motor unplugged, should there be one? It behaves the same as with the motor plugged in, so it shows 'movements' in the dashboard.
    It was bought 12-2019 at ReprapWorld.
  • Moderator
    Can you send M98 P"config.g" ?
  • @Phaedrux said in Single Z-Motor doesn't move:
    M98 P"config.g"
    It shows:
    M98 P"config.g"
    HTTP is enabled on port 80
    FTP is disabled
    TELNET is disabled
  • @JoergS5 the connections seem okay, however I don't known how it should look like:
  • @Eisbar this looks perfect, I could not solder better myself 😉
    This is not the reason.
  • Moderator
    @Eisbar said in Single Z-Motor doesn't move:
    Unfortunately well out of warranty.
    Based on your description and the testing done it does seem like the Z driver has failed.
    You can use the E1 driver for Z by remapping if it's free.
  • @Eisbar I saw that Z is immediately homed, I wonder how the Z position can be 50.
    Can you please check
    G91 G1 H2 Z100
    whether the stepper rotates?
    And then M122 and check the line for driver 2.
    Edit: I see you say tool position changes, but stepper doesn't move. So probably a wrong idea from me. But maybe you try anyway.
    BTW I wonder why your console says Z endstop is triggered, but in your config you disabled endstops. The G1 H2 command above ignores the endstop status.
  • Moderator
    Post your homeall?
    Also, remapping Z to E1 would let us test your current config on a different driver.
  • @JoergS5 said in Single Z-Motor doesn't move:
    I pressed "home Z" and thereafter two times "Z+25", just to check if the motor would move (it didn't).
    G91 G1 H2 Z100
    When I press "Home Z" and thereafter "G91 G1 H2 Z100" the motor also doesn't move, the M122 result is as follow:
    "Driver 2: ok, SG min/max 0/0"
    Which lines does indicates this?
    Thank you for your help so far!
  • @Phaedrux that would be very sad, I just used it a few times in only simular configurations and just started with construction of the printer. As I planned to use E1 for an extruder and E0 for the double Y axis, I could not miss the Z-driver. Is the warranty less than a year?
    Post your homeall?
    M122 after "home all" with Z-motor at E1 (Driver 4), everything works fine:
    Driver 0: standstill, SG min/max 0/244
    Driver 1: standstill, SG min/max 0/276
    Driver 2: ok, SG min/max not available
    Driver 3: standstill, SG min/max 0/249
    Driver 4: standstill, SG min/max 0/250
    M122 after "home all" with Z-motor at Z (Driver 2), Z doesn't rotate:
    Driver 0: standstill, SG min/max 0/247
    Driver 1: standstill, SG min/max 0/295
    Driver 3: standstill, SG min/max 0/288
    I wonder what SG min/max 0/0 means in the last case.
  • Moderator
    Stallguard values. Not sure why it would be 0/0
  • @Eisbar warranty depends on the country, in germany it is 2 years. The first half year without prove, after that you must prove that you didn't damage it. (Obvious damage voids waranty of course)
    But I doubt that the board is defect.
    SG and immediate endstop trigger could be because of your strange config settings. M566 and M201 are very low for Z, could you try higher values in the range of X and Y and try to move Z again?
  • Moderator
    Except that those exact same values work fine when Z is mapped to E1.
    sorry, I overlooked that...
