Calibrate bed temp
Is it any way to calibrate the temp reading from the printbed in RRF3?
I have a PT100 on sensor on my hotend so i trust that reading more than the thermistor. The bed temp 1,9c lower than the reading from the PT100, so i would want to adjust for that.
thermistors are inherently more inaccurate.
normally the thermistors are just stuck to the underside of the bed with some kapton tape.
just get a pt1000 (or even a pt100) like this https://de.aliexpress.com/item/32872179878.html and use for the bed. -
@Veti said in Calibrate bed temp:
just get a pt1000 (or even a pt100) like this https://de.aliexpress.com/item/32872179878.html and use for the bed.That's absolutely an alternative, which of those PT100's would do the trick? (Car mechanic here, so electronic's ain't my strong suit lol).
the one with the lowest tolerance. PT100 Class A.
I have not used a PT100 on the bed, so i dont know how it is in terms of interference.
i use a pt1000 (you can connect them like normal thermistors) -
@Veti
Hmm ok, meh might as well order one of both for the sake of experimentingthanks for the link
