Print Progress Info not working
I just noticed that the print file / progress info is not working - at least when connected to RRF3.
I started off with the latest standalone config default. The relevant values are commented out - but in any case do not reflect the structure returned byrr_status?type=3
I was able to get elapsed time etc. working with code like this :
"value": "${(state.status == 'P') ? DueUI.formatElapsed(state.printDuration) : \"00:00:00\"}",
However current print file and the like are alluding me. It looks like Dueui.js has not yet implemented a call to
rr_fileinfo?name=
Specifically , I'm looking for the fileName - or is there some other way ?
Thanks in advance
@stuartofmt Hmmm. They should be working. I'll take a look.
As a "quick and dirty" i.e. not sure you would want to do it this way ....
I inserted this to dueui.js at line 1358
resp = await super.getJSON("/rr_fileinfo?name="); if (resp.ok) { $.extend(true, this.model, resp.data); }
And use this in my config file to display the current print job name
"value": "Current/Last File: ${(state.status == 'P') ? state.fileName.substring(10) : 'Not Printing'}",
@stuartofmt The currently printing file name should be in the object model already. So does
state.job.file.fileName
not work? -
No - state.job.file.fileName gives an error (see below).
Note that there is no job element returned by the rr_status?type=XXX series of calls (see attached for type=3)
Possible changes in DWC ? I'm using V3.1.1
@stuartofmt Run this CGI from your web browser instead of rr_status...
http://<duet>/rr_model?flags=fnd10
That should return the full model.
@gtj0 said in Print Progress Info not working:
There does not seem to be such a call anywhere in Dueui.js - is it elsewhere?
EDIT: Just realized that this just returns the schema.From the browser (recent chrome) attached is what I get.
In any case - there is no element for job.file, let alone job.file.fileName.
There are only two elements with "file" in the namebut neither of them is a stringbut neither is what we are looking for. -
@stuartofmt dueui.json should never have to do any retrieval itself. dueui.js polls the Duet at the interval you set in settings using the "rr_model" call and keeps the top-level "state" object up to date. That being said, it does look like the model is incomplete so let me look at 3.1.1 and see what the deal is.
Yes - my reference to Dueui.json was a typo - I meant Dueui.js.
A disclaimer - my knowledge of java and js is barely one step above zero and short even of being a novice ( I even get the spelling of file extensions wrong)
The Dueui.js in the version I downloaded (I believe it is the latest) has this as the relevant code (If I am interpreting correctly)
async connect_once(url) { let resp = {}; if (this.connected) { resp.ok = true; return resp; } try { resp = await super.getJSON(`/rr_connect?password=${ encodeURI(this.settings.duet_password) }`); if (!resp.ok) { return resp; } resp = await super.getJSON("/rr_status?type=1"); if (resp.ok) { $.extend(true, this.model, resp.data); } resp = await super.getJSON("/rr_status?type=3"); if (resp.ok) { $.extend(true, this.model, resp.data); } return resp; } catch(error) { console.log(error); resp.error = error; resp.ok = false; } return resp; }
I will double check but it seems like the call /rr_status?type=1 may be redundant as all the info looks to be included in /rr_status?type=3
I added this your Dueui.js as an additional call to get the filename
Hope this helps - I realize this is not your day job
@stuartofmt OK, I'm an idiot. I'm looking at code I hadn't pushed up yet. The day job is killing me this week but I promise I'll have everything corrected and pushed up by Sunday.
Don't rush on my behalf. I have got most everything working. I just did not want to go too far down a path that may end up being incompatible with your base code.
Again - Thanks for a terrific enhancement to the Duet world!
P.S. I posted my efforts in the configuration thread. Unfortunately this was before I noticed that the print info was not coming through. I will have a V3 shortly but did not want it to have to rely on my mods to dueui.js.
P.P.S. I have a couple of other suggestions / observations that I will put in separate threads tomorrow,
I can confirm that type=3 is a superset of type=1 - so it does indeed look like type=1 may be redundant (in the context of Dueui)
I suspect that the object model has evolved over time and is now more structured / consistent. -
Still working on stuff. Wll be Monday before teh next release.
Things should be working much better now. Give the new release a try.
