    Suggestion on Filelist sort order
    DueUI
    632
    • stuartofmtundefined
      stuartofmt
      The current filelist sort order is alphabetic. - which has a certain appeal.
      Mostly though - I find myself wanting to reprint one of the most recently downloaded files - especially if I have a couple with slightly different settings that I am trying to get right.
      It would be great if there was a configuration option to have the list sorted by date.
      Thanks in advance.
        jay_s_uk @stuartofmt
        @stuartofmt just click the column name and it will sort by that
        stuartofmtundefined 1 Reply Last reply Reply Quote 0
          stuartofmt @jay_s_uk
          @jay_s_uk
          Which column name are you referring to ? I'm using DueUI. I do not see any column names in the widget ??
            stuartofmt
            This is the quick hack I made to Dueui_widget.js (see comments) -- but it's not exactly configurable .....
            class DueuiFileDropdownWidget extends DueuiSelectWidget {
            	constructor(config, parent){
            		super($.extend(true, {
            		}, config), parent);
            		this.refresh();
            //Added to force sort by date
                    this.sort="date";
            <snip>
            	async refresh() {
            		this.jq.empty();
            		let files = await dueui.getFileList(this.directory);
            		let options = [];
            		this.jq.append(`<option value="#####">Select a file...</option>`)
            		for (let fe of files) {
            //added date element to allow sorting
            			options.push({"value": fe.name, "label": this.formatName(fe.name), "date": fe.date});
            if (this.sort &&
            			(this.sort === "label" || this.sort === "file")) {
            			if (this.sort === "file") {
            				this.sort = "value";
            			options.sort((a, b) => {
            				return a[this.sort].localeCompare(b[this.sort]);
            //else if added for date sorting
            		} else if (this.sort === "date"){
            			options.sort();
            			options.reverse();
            		} else {
            			options.sort();
            <snip>
              @stuartofmt sorry, my bad. Missed this was in the dueui category.
              Disregard my comment
                @jay_s_uk
                NP - in an active forum like this - it's easy to do 😷
                • gtj0undefined
                  gtj0
                  I can add that to the config for the widget.
                    stuartofmt @gtj0
                    @gtj0
                    I just realized that changing the sort setting in the config file to:
                    				"element_configs": [
                    						"id": "selectafile",
                    						"type": "file_select",
                    						"directory": "/gcodes/",
                    <snip>
                    						"sort": "date",
                    <snip>
                    and also making the suggested changes to dueui_widget.js (without the line this.sort="date" ) makes it easily switchable.
                      stuartofmt
                      @gtj0
                      Since I have been fiddling to gain a better working knowledge of js. Thought I'd pass on my attempt to rewrite the relevant portion of the filelist code.
                      If it's useful / saves you some time - great. If not, it was an interesting exercise.
                      	async refresh() {
                      		this.jq.empty();
                      		let options = [];
                      		let element = {};
                      		element["value"] = fe.name;
                      		element["label"] = this.formatName(fe.name);
                      		if (this.sort === ("date"||"size")) {   //the current possible values are only type, name, size, date
                      		element[this.sort] = fe[this.sort];
                      		options.push(element);
                      // Set the sort element
                      if (this.sort !== ("date"||"size")) {
                      // Sort ascending by default
                      options.sort((a, b) => {return a[this.sort].localeCompare(b[this.sort]);});
                      // Reverse it if necessary
                      if (this.ascending === false) {
                      			options.reverse();
                      The default (no sort or ascending variable) as alphabetic ascending.
                      For descending by date - I add these values in my config file.
                      <snip>
                      		"sort": "date",
                      		"ascending": false,
                      <snip>
                        stuartofmt
                        Of course - as I went to sleep, I realized that (1) the if statement inside the iteration loop was not a good idea and (2) at a practical level, there were only three use-cases and (3) the sort on size was wrong.
                        So here is at least a better attempt.
                        	async refresh() {
                        		this.jq.empty();
                        		let options = [];
                        		if (this.sort === "date") {
                        		} else if (this.sort === "size"){
                        				options.push({"value": fe.name, "label": this.formatName(fe.name), "size": fe.size});
                        		} else {
                        				options.push({"value": fe.name, "label": this.formatName(fe.name)});
                        	} else if (this.sort === "size") {
                        		options.sort((a, b) => {return parseInt(a[this.sort]) - parseInt(b[this.sort]);});
                        	} else {
                        // Sorted ascending by above
                        			options.reverse();
                          stuartofmt
                          I woke this morning recognizing the two main if statements - in the above - can now be merged - making the whole thing quite tidy.
