Mainboard fan not turning on
I have noticed my mainboard fan isnt spinning when i checked it was at 54C
part cooling and thermostatically controlled hotend fan is working fineheres the config.g of the fans;
M106 P0 C"PCF" S0 I0 F500 H-1 ; set fan 0 name, value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 C"HEF" S1 I0 F500 H1 T45 ; set fan 1 name, value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 C"ECF" S1 I0 F500 H1:0 T45 ; set fan 2 name, value, PWM signal inversion and frequency. Thermostatic control is turned on -
P2 is the mainboard fan?
How is the sensors set up?
Maybe it's being pedantic. Try listing the heaters as H0:1
Does the fan work if you send M106 P2 H-1 S1?
