Cases for addon boards
Is anyone aware of any cases for Duet 3 Toolboard 1LC and Duet 3 Tool Distribution Board?
I would like to mount them on 3030 extrusion. Even if the case doesn't support 3030, I could just drill extra holes if needed. Just need enclosure, even if its only good enough for temporary use.So far have only found this one for the toolboard... https://www.thingiverse.com/thing:4529342
Thanks!
the toolboard is meant to be mounted onto a nema17 motor of a direct drive system.
