    Duet feedback in Yat
    • Atrusbearundefined
      Atrusbear
      I am not getting any feedback from my Duet using Yat. Because of this I am not able to get my Duet to connect to my wifi. How can I fix this and connect to my wifi?
      • A Former User?
        A Former User
        Can you took under Device Manager to see what device the COM1 port is?
          Atrusbear
          no, but everytime I try to update the driver with the duet driver it says it is up to date and doesn't do anything.
            But in device manager does it show as a Duet or as a bossa port? If it shows as a bossa port, it means there is no firmware on the board and it must be flashed.
            https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond#Section_Connect_to_a_PC_via_USB_and_look_for_the_port
