    settings new corexy speeds
    403
    • Jomiagundefined
      Jomiag
      Hello, forgive my English. I just recently finished my corexy, it has linear guides and the structure is very very firm. I'm testing speed settings with good results in general, but I don't understand much if they're well compensated and I'd like to be recommended with the features of my printer a good base setup to start, both in xzy-movements and extrusion parameters. Thank you
      my parameters
      ; set drive mapping
      M350 Z16:16 E16 I0 ; configure microstepping without interpolation
      M350 X16 Y16 I1 ; configure microstepping with interpolation
      M92 X100 Y100 Z1600:1600 E415 ; set steps per mm
      M566 X600 Y600 Z12:12 E120 ; set maximum instantaneous speed changes (mm/min)
      M203 X9000 Y9000 Z1000:1000 E1200 ; set maximum speeds (mm/min)
      M201 X1000 Y1000 Z150:150 E150 ; set accelerations (mm/s^2)
      M906 X600 Y600 Z500:500 E400 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      this is my corexy, direct extruder, e3dv6 with barrel bi-metal, nema 17hs4401, z screew pitch 2
      https://i.ibb.co/H2b2xML/1607939862417.jpg
      https://i.ibb.co/rvN7yMJ/1607939862430.jpg
      https://i.ibb.co/0XLsXJF/1607939862439.jpg
      mrehorstdmdundefined 1 Reply Last reply Reply Quote 0
        jay_s_uk
        If you are mapping a second motor to the z axis, you don't need to double up everything.
        It is sufficient to have M584 Z2:4.
        M350 Z16:16 should be come M350 Z16 and so on.
        The E3D toolchanger is a good example to look at.
        It can be found here https://github.com/Duet3D/RRF-machine-config-files
        There is also the jubilee toolchanger and its configs can be found here https://github.com/machineagency/jubilee/tree/master/software/duet_config_files
        Both of the above are corexy printers with good sturdy frames
        • Jomiagundefined
          Jomiag
          thanks i start testing!
          • Jomiagundefined
            Jomiag
            are they good values?
            ; set drive mapping
            M92 X100 Y100 Z1600 E415 ; set steps per mm
            M566 X1000 Y1000 Z100 E1500 ; set maximum instantaneous speed changes (mm/min)
            M203 X24000 Y24000 Z900 E3600 ; set maximum speeds (mm/min)
            M201 X3000 Y3000 Z100 E150 ; set accelerations (mm/s^2)
            M906 X600 Y600 Z500 E400 I30 ; set motor currents (mA) and motor idle factor in per cent
            • mrehorstdmdundefined
              mrehorstdmd @Jomiag
              @Jomiag I would suggest that you redesign the XY motor mounts (and maybe Z, too) to increase rigidity. As they are, belt tension is going to cause them to flex and tilt the motors. That will increase wear on the belts/pulleys.
              Something like this (the green one) will be much more rigid:
              • theruttmeisterundefined
                theruttmeister
                He already has braces below the motors, mirroring that upwards would be just as good, and probably faster to print as well...
                Designing and building your own printer never stops 🙂
                Isolate, substitute, verify.
                • Jomiagundefined
                  Jomiag
                  [url=https://ibb.co/bLHRrdh][img]https://i.ibb.co/RPh4CHn/IMG-20201214-195406.jpg[/img][/url]
                  [url=https://ibb.co/KmNNDdW][img]https://i.ibb.co/N711r5K/IMG-20201214-195416.jpg[/img][/url]
                  He already has it. Thanks for the suggestion
                  • Jomiagundefined
                    Jomiag
                    The nominal voltage of my motors is 1.5A
                    According to what I have been able to inform myself, the ideal is to put them at 80%, that is, 1200 but I have them in xy 600 in z with step screw 2 to 500 and in the extruder with bondtech at 400 .. It does not lose steps but. Is it bad to have them so low? It's that they make less noise like that.
                      80% is just the rule of thumb to ensure solid accurate movement and high acceleration without skipping steps. You can get away with lower. When it might come into play is if the nozzle contacts a curled edge, it may skip rather than push through. Or on a long print when the motors warm up they may become more prone to skip, so do some testing.
