    SOLVED Another BLTOUCH Issue
    Third-party add-ons
    • SirNitro
      SirNitro last edited by
      With the vast amount of information pertaining to BLTouch this should have been a quick and easy fix but yet here we are several days later.
      Not a clone bltouch purchased directly from ANTCLABS
      If I issue a M401 or M402 command I get an error stating "Invalid servo index 0 in m280 command"
      Board: Duet Maestro 1.0 (duetmaestro100)
      Firmware: RepRapFirmware for Duet 2 Maestro 2.05.1 (2020-02-09b1)
      Thank you
      Below are my configs
      ; Configuration file for Duet Maestro (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.2.0 on Fri Dec 25 2020 23:16:24 GMT-0500 (Eastern Standard Time)
      M550 P"XXXXXX"                                ; set printer name
      M551 P"XXXXXX"                                   ; set password
      M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
      M569 P0 S1                                         ; physical drive 0 goes forwards
      M569 P1 S1                                         ; physical drive 1 goes forwards
      M569 P2 S1                                         ; physical drive 2 goes forwards
      M569 P3 S1                                         ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E420.00                  ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
      M208 X230 Y210 Z200 S0                             ; set axis maxima
      M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      M950 S0 C"zprobe.mod"                             ; create servo pin 0 for BLTouch
      ;M558 P9 C"^zprobe.in" H5 F120 T6000                ; set Z probe type to bltouch and the dive height + speeds
      M558 P9 C"^zprobe.in" H5 F100 T2000
      G31 P500 X0 Y0 Z2.5                                ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20                           ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
      ; deployprobe.g
      ; called to deploy a physical Z probe
      M280 P0 S10 ; deploy BLTouch
      ; retractprobe.g
      ; called to retract a physical Z probe
      ; generated by RepRapFirmware Configuration Tool v3.2.0 on Fri Dec 25 2020 23:16:25 GMT-0500 (Eastern Standard Time)
      M280 P0 S90 ; retract BLTouch
      DIY-O-Sphere 1 Reply Last reply Reply Quote 0
      • DIY-O-Sphere
        DIY-O-Sphere @SirNitro last edited by DIY-O-Sphere
        @SirNitro
        You have to choose the right Firmware version.
        (UTC+1)
          The issue is that your config is for RRF3 but you say you have 2.05.1 flashed.
          Either redo your config selecting RRF2, or update your board to 3.0 and then 3.1.1.
          • SirNitro
            Now I feel like a moron..
            Thank you everything is working with the BLTouch now.
              Non-sense. Happens to the best of us.
