    After Upgrade to 3.2 no temp reading for bed
    Firmware installation
    • chronos
      chronos last edited by
      after i upgraded my Duet Wifi to 3.2 the temp reading for the bed on the web server was gone.
      The reading from the extruder shows up and is fine.
      Does it have to be activated somehow?
      I switched the temp sensor with the one from the extruder and got a reading so the wiring and sensor should be ok.
      I also upgraded the Duet Web Control to 3.2
      any ideas?
        Post your config.g
        Post the results of M122
        Post the results of M98 P"config.g"
        • chronos
          ok
          config.g
          M550 P"Ender 3 Pro" ; set printer name
          M918 P1 E4 F2000000 ; configure direct-connect display
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0 S1 ; physical drive 0 goes backwards
          M569 P1 S1 ; physical drive 1 goes backwards
          M569 P2 S0 ; physical drive 2 goes forwards
          M569 P3 S0 ; physical drive 3 goes backwards
          M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
          M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X235 Y235 Z260 S0 ; set axis maxima
          M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
          M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
          M557 X15:215 Y15:195 S20 ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
          M143 H0 S150 ; set temperature limit for heater 0 to 150C
          M307 H0 A190.5 C538.4 D0.9 S1.00 V24.1 B0 ; disable bang-bang mode for the nozzle heater and set PWM limit
          M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
          M143 H1 S275 ; set temperature limit for heater 1 to 275C
          M307 H1 A329.3 C112.3 D4.1 S1.00 V0.0 B0 ; disable bang-bang mode for the nozzle heater and set PWM limit
          M106 P2 S1 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
          Board ID: 08DJM-9178L-L4MSJ-6JTDG-3SS6M-9802Q
          Used output buffers: 3 of 24 (14 max)
          Static ram: 23460
          Dynamic ram: 77124 of which 40 recycled
          Never used RAM 11456, free system stack 189 words
          Tasks: NETWORK(ready,183) HEAT(blocked,307) MAIN(running,448) IDLE(ready,19)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:03:38 ago, cause: power up
          Last software reset at 2021-01-10 03:59, reason: User, GCodes spinning, available RAM 11408, slot 1
          Error status: 0x00
          Aux0 errors 0,0,0
          MCU temperature: min 20.4, current 25.7, max 25.9
          Supply voltage: min 24.2, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, SG min/max not available
          Driver 1: position 0, standstill, SG min/max not available
          Driver 2: position 0, standstill, SG min/max not available
          Driver 5: position 0
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2021-01-10 09:27:04
          Cache data hit count 270283242
          Slowest loop: 7.77ms; fastest: 0.21ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.9ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 18.77ms; fastest: 0.00ms
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.25
            WiFi MAC address cc:50:e3:e3:ad:d3
            WiFi Vcc 3.36, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 24176
            WiFi IP address 192.168.178.46
            WiFi signal strength -71dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
            Looks like you've upgraded from RRF 3.0 or earlier. Since RRF 3.1 there has been no default bed heater. You need to add M140 H0 to declare the bed heater, after the M950 H0 command.
            • chronos
              @dc42 said in After Upgrade to 3.2 no temp reading for bed:
              M140 H0
              It works now
              thanks for your quick support 👍
