    G29 causes error
    • Reefwarriorundefined
      Reefwarrior
      Hi all,
      The above refers. When doing a X Y and Z homing, there is no issue; but as soon as I try and do a G29, I get 'Error: Z probe already triggered before probing move started'
      My Z probe is a pin with a flag triggering an optical endstop - and a servo is used to 'extend' or 'retract' the pin for usage.
      Any/all help appreciated!
      Tinus 🙂
      • Vetiundefined
        Veti
        run M401 before the G29
          Reefwarrior
          Thanks, working. Thought it would automatically deploy the probe upon start of G29?
          • Vetiundefined
            Veti
            you are right. and it does for me.
            maybe you need a delay with G4 in your deploy if it takes a few ms
            Reefwarriorundefined 1 Reply Last reply Reply Quote 0
              Reefwarrior @Veti
              @Veti Thanx will try 🙂
                Reefwarrior
                Ok I solved it. I mistakenly declared my Z probe incorrectly. Changed it to P5 and now it work as expected....
