    small change, restart board and now no connection?
    277
    • Adamfilipundefined
      Adamfilip
      Printer was working fine, but I was tweaking the motor
      I was adjusting setting to the Stepper motor setting.. I changed
      M569 P1 S0 to M569 P1 S1
      saved then reset..
      and now wifi isnt flashing anymore. not even trying to connect..
      feeling very frustrated at the moment.
      • fcwiltundefined
        fcwilt
        Best thing to do at this point is post your config.g file
          If you're still unable to connect to the wifi after a couple reboots you'll have to connect it to USB terminal (unless you have a Paneldue to use) and see what the firmware is doing when you send M552 S1.
          If you're still having problems then, post your config.g and the results of M122 here.
            Adamfilip
            The Config.g file was blank.. I copied over the backup and now it boots again..
            Why would it erase it
              SD card failing perhaps?
              • fcwiltundefined
                fcwilt @Adamfilip
                @Adamfilip said in small change, restart board and now no connection?:
                Occam's Razor would suggest that some sort of user error was the cause.
                Then again it might be a firmware bug.
                  Adamfilip
                  I was just using webcontrol, typed a change.. hit save.. it asked me if i wanted to restart.. i said yes and then it didnt restart.. not sure what I could have done differently..
                  The MicroSD card is only 6 months old and Sandisk brand.
                  be surprised if this is faulty
                  • fcwiltundefined
                    fcwilt @Adamfilip
                    Had the SD card failed in someway I could see the file being gone or corrupt but not perfectly fine yet blank.
                    So if no user error then were back to a firmware issue I guess.
                      Phaedrux Moderator @Phaedrux
                      @Phaedrux said in small change, restart board and now no connection?:
                        Adamfilip
                        M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
                        Board ID: 08DLM-996RU-N85T0-6JKF2-3SJ6Q-1AVVR
                        Used output buffers: 3 of 24 (17 max)
                        Static ram: 23460
                        Dynamic ram: 73136 of which 88 recycled
                        Never used RAM 15396, free system stack 103 words
                        Tasks: NETWORK(ready,165) HEAT(blocked,295) MAIN(running,450) IDLE(ready,19)
                        Owned mutexes: WiFi(NETWORK)
                        Last reset 12:21:13 ago, cause: software
                        Last software reset at 2021-01-18 20:55, reason: User, GCodes spinning, available RAM 15396, slot 0
                        Error status: 0x00
                        Aux0 errors 0,0,0
                        MCU temperature: min 30.6, current 32.3, max 35.5
                        Supply voltage: min 23.8, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                        Driver 0: position 2000, standstill, SG min/max 0/387
                        Driver 1: position 0, standstill, SG min/max 0/355
                        Driver 2: position 28884, standstill, SG min/max 0/1023
                        Driver 3: position 0, standstill, SG min/max 0/1023
                        Driver 5: position 0
                        Driver 6: position 0
                        Driver 7: position 0
                        Driver 8: position 0
                        Driver 9: position 0
                        Driver 10: position 0
                        Driver 11: position 0
                        Date/time: 2021-01-19 09:16:30
                        Slowest loop: 62.83ms; fastest: 0.16ms
                        === Storage ===
                        Free file entries: 10
                        SD card longest read time 4.2ms, write time 0.0ms, max retries 0
                        DMs created 83, maxWait 204110ms, bed compensation in use: mesh, comp offset 0.000
                        === MainDDARing ===
                        Scheduled moves 1705, completed moves 1705, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                        === AuxDDARing ===
                        Heater 0 is on, I-accum = 0.0
                        Heater 1 is on, I-accum = 0.5
                        Segments left: 0
                        Movement lock held by null
                        HTTP is idle in state(s) 0
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Trigger is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Code queue is empty.
                        === Network ===
                        Slowest loop: 21.54ms; fastest: 0.00ms
                        HTTP sessions: 1 of 8
                        - WiFi -
                        Network state is active
                        WiFi firmware version 1.25
                        WiFi MAC address 84:0d:8e:b2:f8:6f
                        WiFi Vcc 3.32, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 21808
                        WiFi IP address 192.168.0.182
                        WiFi signal strength -30dBm, mode 802.11n, reconnections 0, sleep mode modem
                        Clock register 00002002
                          Thanks. Hopefully just a one off. First report I've seen of this. If it happens again do let us know.
