    Question about G30 and firmware 3.2
    • fcwilt
      fcwilt last edited by fcwilt
      I've been testing my new Duet 3 Mini 5 board with firmware v3.2
      Working on Z probe testing - I have this in config.g:
      M558 P5 C"!^io0.in" H2 F120 T10000 R0.2 A1 S0.03
      G31 P500 X0 Y0 Z5
      When executing a G30 the Z stepper starts to move in the a correct direction and when I trigger the Z probe the stepper stops and the Z coordinate is set.
      The docs say this about G30:
      G30 ; Probe the bed at the current XY position. When the probe is triggered, set the Z coordinate to the probe trigger height.
      Now the "probe trigger height" mentioned is the value of the Z parameter in the G31 - correct?
      However the Z coordinate is actually being set to the sum of the Z probe trigger height from G31 and the Z probe dive height from M558.
      Is that a bug or just how G30 works.
      Thanks much.
      • Veti
        Veti last edited by
        @fcwilt said in Question about G30 and firmware 3.2:
        Is that a bug or just a change in how G30 works.
        that is how it works.
        then the probe is trigged z is set to 5. then the probe moves out of the way as defined by H
        so you end up with z=7
        fcwilt 1 Reply Last reply Reply Quote 0
        • fcwilt
          fcwilt @Veti last edited by
          @Veti said in Question about G30 and firmware 3.2:
          Thanks.
          It seems that I just never noticed it before - when I looked at the locations on my printers gcode where G30 was used it was always followed by a Z move.
