duet3d sd not detected, rejects http, com5 denied
@Phaedrux
so i put these files on the sd card then run the M commands ? -
No. Upload them to the system tab in the web interface. One zip file at a time. Start with 2.05.1. It will prompt you to update. And reboot.
@Phaedrux
Failed to upload network error
M552 S1 say wifi is ok -
And you're trying to upload it to the system tab?
Can you go to the console tab and send M122 and copy and paste the results?
This post is deleted! -
In the system tab you'd find your config.g and the homing files, etc.
That's where you would upload Duet2Firmware-2.05.1.zip
@Phaedrux
yes in the system tab under file management on the left, is where I tried to upload it, the file does not show up in other tabs -
And you're using the upload file button?
Can you post a screen shot of the error?
@Phaedrux
what file format do i need to save the screen shot as to upload it here? -
If you're on windows you can use the print screen button on your keyboard and paste that into paint and save it as a jpeg.
I kept retrying it over and over and eventually it uploaded.
trying to get the 2nd file to load now. it wont get past the 4th file thoWiFi module is connected to access point 111111 IP address 11111111
Trying to connect at 230400 baud: success
Erasing 4096 bytes...
Erasing 212992 bytes...
Uploading file...
5% complete
10% complete
15% complete
20% complete
25% complete
30% complete
35% complete
40% complete
45% complete
50% complete
55% complete
60% complete
65% complete
70% complete
75% complete
80% complete
85% complete
90% complete
95% complete
Upload successful -
2nd file finally uploaded
Are you uploading the zip file as is? Don't extract it first.
@Phaedrux
Im not unzipping it. I go to upload the file it fails.... upload file it fails...
upload the file it loads 1/17 then fails... upload again 2/17 then fails and eventually it loads all the files then updates. usually between files Im having to wait some time to try the next file or it doesn't work at all.
im working on the 3rd zip nowIm having more trouble with the 3rd then the first 2
I can only get it to 5 / 55 files before failing -
When and where did you purchase the Duet?
Uploading the zip files shouldn't be this painful. Could be SD card writing problem or it could be the wifi module.
@Phaedrux
i just got it a few days ago and i ordered it from matter hackers because the duet page was sold out. -
Did the last zip file finally upload successfully?
If you go to the general and machine specific tabs in the DWC what versions are shown for the firmware and web interface? 3.2?
Are you able to upload a sliced gcode file to the gcodes tab successfully?
No I still have not gotten it to load yet.
is there another way to do this ? maybe through YAT. it keeps saying network error.
