Yet Another BLTouch Post
Hi All,
I have a DUET II Ethernet with a BLTouch Smart-3.1. The firmware is 3.2.
I believe I have it wired correctly in that I can successfully issue M401 and M402 commands. With the probe retracted the BLTouch is red. With the probe deployed the BLTouch is not lit.
When I issue a G30 command, the probe deploys and the Z axis moves down. When I tap the probe to interrupt the G30 command, the Z axis retracts 5mm and then begins to go down as it tries to probe again.
What information to I need to provide to assist with troubleshooting?
Thank you,
Darren
; deployprobe.g
; called to deploy a physical Z probe
; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 25 2020 11:55:10 GMT-0400 (Eastern Daylight Time)
M280 P0 S10 ; deploy BLTouch
;M280 P0 S10 I1; deploy BLTouch; retractprobe.g
; called to retract a physical Z probe
M280 P0 S90 ; retract BLTouch
;M280 P0 S90 I1; retract BLTouch; homez.g
; called to home the Z axis
G91 ; relative positioning
G1 H1 Z-150 F1800 ; move Z down until the endstop is triggered
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning; From Duet FAQ
;G91 ; relative mode
;G1 S2 Z4 F200 ; raise head 4mm to ensure it is above the Z probe trigger height
;G1 H1 Z4 F200 ; raise head 4mm to ensure it is above the Z probe trigger height
;G90 ; back to absolute mode
;G1 X100 Y100 F2000 ; put head over the centre of the bed, or wherever you want to probe
;G30 ; lower head, stop when probe triggered and set Z to trigger height; homeall.g
; called to home all axes
G1 H1 X205 Y-205 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X-5 Y5 F6000 ; go back a few mm
G1 H1 X205 Y-205 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z-150 F360 ; move Z down stopping at the endstop
;G90 ; absolute positioning; Z-Probe
M307 H3 A-1 C-1 D-1
M558 P9 C"^zprobe.in" H5 F120 R0.2 T6000 A5 B1 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X28 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
;G31 X28 Y0 Z0.5 P25
M557 X15:185 Y15:185 S25 ; define mesh grid -
@DGEllis said in Yet Another BLTouch Post:
M307 H3 A-1 C-1 D-1
this is not a valid command in version 3
the H5 says after triggering move the z axis down by 5. does that answer your question?
Hi Veti,
Thank you for your reply.
I checked test the G30 command and waited, this time, to see if it stopped. It did, after moving down 5mm.
I appreciate your quick assistance.
Thank you,
Darren
I now can complete the probe test, and can home Z as well as home all.
When I run G29, at the first probe, when the probe retracts, the G29 operation stops with "Error: Z probe was not triggered during probe move." Yet, the pin is retracted.
I get this same error during calibration with G30 S-1.
Am I missing something?
Thank you,
Darren
retract the pin and post the output of m119
1/29/2021, 11:43:18 AM M119
Endstops - X: at max stop, Y: at min stop, Z: not stopped, Z probe: not stopped -
thats can happen if your bed is badly aligned.
have you levelled the bed with paper before probing? -
TBH, I didn't. I thought I left it leveled after my last job, but I will do so right now.
Thanks again for all your assistance.
Darren
; homeall.g
G92 Z0 ; set Z position to axis minimum (you may want to adjust this)Your homeall and homez are configured to use an endstop, not the probe.
G1 H1 Z-150 F360 ; move Z down stopping at the endstop G90 ; absolute positioning G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
Replace that with this
G90 ; absolute positioning G1 X150 Y150 F6000 ; move probe to center G30 ; probe the bed
Hi Phaedrux,
I corrected that issue after I made this post and didn't update the post. I do appreciate, however, the way to move the print head to the center of the bed.
Thank you much!
Darren
PS: I looked at your ZBot. Sharp looking and prints really well too. Awesome work!
Hi All,
Many thanks to Veti and Phaedrux for timely and accurate assistance. My heavily modified FT 2020 Prusa I3 now can complete a G29, consistently. Thanks guys!
I found another problem. How do I set the Z 0 height? Probing leaves the head too high up so I don't get adhesion, let alone a good first layer.
I used to do it with the Z end stop. I am missing something critical.
What am I missing?
Thank you,
Darren
@Phaedrux said in Yet Another BLTouch Post:
; homeall.g
What am I missing?You need to use the probe to homez.
You need to measure the XYZ offset for the probe.
See here: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe -
Ahah! I have the wrong Z offset.
Thank you!
Darren
