Touch-Mi deployprobe.g not working
I have a Touch-mi Z probe and also a Z endstop
After I homeall, If I send a M401 to deployprobe nothing happens
not sure why
Config
; Drives M569 P0 S0 ; physical drive 0 goes backwards previously P0, p5 is on expansion board M569 P1 S0 ;M569 P8 R0 S0 T3.33:3.33:3:0 ; physical drive 0 goes backwards previously P0, p5 is on expansion board S42B ;M569 P5 R0 S1 T3.33:3.33:3:0 ; physical drive 1 goes backwarsa previously P1, p8 is on expansion board S42B M569 P2 S0 ; Z physical drive 2 goes backwards M569 P3 S1 ; Extruder physical drive 3 goes Forwards M584 X0 Y1 Z2 E3 ; set drive mapping , ;M584 X8 Y5 Z2 E3 ; set drive mapping , old X0 Y1 S42B M350 X32 Y32 Z32 I0 ; configure microstepping without interpolation, previously 32 M350 E16 I1 ; configure microstepping with interpolation M92 X200 Y200 Z1593 E409 ; set steps per mm M566 X600 Y600 Z20 E800 ; Set maximum instantaneous speed changes (mm/min) JERK M203 X9000 Y9000 Z1500 E10000 ; Set maximum speeds (mm/min) M201 X1000 Y1000 Z250 E5000 ; Set accelerations (mm/s^2) M906 X800 Y800 Z800 E1300 I30 ; Set motor currents (mA) and motor idle factor in per cent X1800 Y1800 Z1500 M84 S30 ; Set idle timeout M572 D0 S0.0125 ; Pressure Advance ; Set idle timeout ; Axis Limits M208 X-10 Y-22 Z0 S1 ; set axis minima M208 X300 Y265 Z300 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; X min active high endstop switch M574 Y1 S1 P"ystop" ; Y min active high endstop switch M574 Z1 S1 P"Zstop" ; Y min active high endstop switch ; Z-Probe M558 P8 F500 H10 I0 T4000 ; touch me probe G31 P500 X-6 Y-48 Z0 M557 X40:240 Y40:240 S100 ; define mesh grid S50 = Spacing 50mm
sys\deployprobe.g
; deployprobe.g ; this is a manual probe deployment by touching the Touch-Mi Probe ; with the magnet included. G91 ; relative positioning G1 Z10 F600 S2 ; lift Z relative to current position G90 ; absolute positioning G1 Y10 F1800 ; move X to zero G1 X270 F1800 ; move X to zero M564 S0 ; allow movement into Minima Y-10 G1 Y-10 F600 ; move Y to -10 slowly G1 X300 F200 ; move Xto 300 very slow to pull magnet across G1 Y0 F600 ; move Y to 0 slowly G91 ; relative positioning G1 Z10 F600 ; move Z by 10 slowly G90 ; absolute positioning G1 X0 F1000 ; move X to 0 slowly M564 S1 ;limit axis movement M291 P"Trigger Magnet" S3 ; prompt for magnet action
How are you issuing the M401 command?
just via Console after homing to test it
@Adamfilip said in Touch-Mi deployprobe.g not working:
And you get no movement, no dialog, no errors?
right, nothing happens.
Strange
What firmware version are you using?
If you haven't done this issue M98 P"config.g" and see if you get any errors.
If you haven't done this create a deployprobe.g with just a M291 command to verify that it executed and test M401 against that.
@fcwilt said in Touch-Mi deployprobe.g not working:
M98 P"config.g"
Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2 (2021-01-05)
Duet WiFi Server Version: 1.25With Just M291 the message does not appear
M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled Error: Missing Z probe pin name(s) Error: Invalid Z probe index Error: Pin 'fan1' is not free Error: Fan number 2 not found
I'll be right back - I'm going to test something.
OK the error on line 5 is preventing the probe from being configured and thus M401 does nothing.
You are missing the M558 C parameter specifying the input pin.
The error on line 6 may be caused by the M558 I parameter which is not a valid parameter for version 3 firmware
Can you post your full config.g?
Have you seen this? https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Touch_Mi
The M558 needs to be updated for RRF3 syntax as fcwilt indicates.
https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M558_in_RepRapFirmware_Num_3
What pin are you using?
Once we figure out the correct syntax I'll update the instructions for the touch-mi to include that. Probably C"zprobe.in"
ok so i will update to the following
M558 P8 C"^zprobe.in" F500 H10 T4000 ; touch me probe
perhaps this guide regarding Touch-Mi should be updated for RRF3
@Phaedrux said in Touch-Mi deployprobe.g not working:
Once we figure out the correct syntax I'll update the instructions for the touch-mi to include that. Probably C"zprobe.in" -
@Phaedrux using ZProbe Pins on Duet2wifi
If you confirm it's working I will update that page.
havent had a chance to test, running some long prints this week
