BL Touch Issue on 3.2 Firmware
Just setup a bl touch on duet 2 wifi after some fiddling and browsing this forum I found most of the answers to get it to answer to commands M401/402 and macros for self test etc. So all that works, however i'm still stuck with the machine reading 1000 for the probe right after boot up. I tried inverting M558 but that didn't help.
Here is my config.g also i'm connected to pin 8 (heater 3)
; Configuration file for Duet WiFi (firmware version 2.03) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Apr 07 2020 00:35:24 GMT-0400 (Eastern Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"SK GO" ; set printer name M667 S1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S0 ; physical drive 2 goes forwards M569 P3 S0 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X100.34 Y100.03 Z401.80 E417.43 ; set steps per mm M566 X1800.00 Y1800.00 Z120.00 E2500.00 ; set jerk (mm/min) M203 X9000.00 Y9000.00 Z1200.00 E5000.00 ; set max speed (mm/min) M201 X2000.00 Y2000.00 Z250.00 E2500.00 ; set acceleration (mm/s^2) M906 X800 Y800 Z800 E600 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout M572 D0 S0.085 ; set guesstimate pressure advance ;M593 F40 ; cancel ringing at xHz ; Axis Limits M208 X-4:304 Y-3:312 Z 0:255 ; set axis limits ; Endstops M574 Z0 S0 ; set active low and disabled endstops M574 X1 Y1 S3 ; set endstops controlled by motor stall detection ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 R4700 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M307 H0 B0 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.196220e-7 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C M950 H3 C"nil" ; Disable heater h3 ; Z-Probe M574 Z1 S2; M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch M558 C"!zprobe.in" P9 H10 F800 T2000 ; set Z probe type to switch and the dive height + speeds G31 P25 X26 Y0 Z-0 ; set Z probe trigger value, offset and trigger height M557 X45:255 Y40:260 S38 ; define mesh grid ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined M501 ; Load latest ;BL Touch M280 P0 S160 I1 ;Clear error state M402 ;Retract BL Touch
Thanks for the help!
@Achtepa said in BL Touch Issue on 3.2 Firmware:
remove the ! and put a ^ in place
but if the display is 1000 after that you have a wiring problem.
post a picture of your wiring
@Veti said in BL Touch Issue on 3.2 Firmware:
That was it! thanks alot!
