UNSOLVED Bl touch z offset
I cant get my Bl touch z offset right. I have an ender 3 pro and iv fallowed many guides none of them have fixed my problem. first when it looks right the front of the print is fine but the back is to lose any help would be helpful. i am new to 3d printing so if im doing something wrong its probably because of that.
What are you using the probe for?
BL touch
if its fine at the front but not at the back then the issue is with your bed levelling not the offset.
This is the macro I use for levelling my bed on my ender 3M671 x29:198:29:198 y35:35:204:204 P0.5 ; The location of the four bed securing screws G28 Z ; Home Z M558 F240 G30 P0 X29 Y35 Z-99999 ; probe near an adjusting screw ; Front left screw G30 P1 X198 Y35 Z-99999 ; probe near an adjusting screw ; Front right screw G30 P2 X29 Y204 Z-99999 ; probe near an adjusting screw ; Rear left screw G30 P3 X198 Y204 Z-99999 S4 ; probe near an adjusting screw ; Rear right screw G28 Z ; Home Z
Run this and it will tell you how much each corner needs adjusting.
