Tools with offsets move past axis limits
Why can the tool move < 0 on X when my axis minimum is 0, even if the tool has an offset? I am not using M564 anywhere. Seems like the idea of a tool offset isn't just to line up with other tools, and to locate itself on the workpiece, but also to avoid overrunning end stops. What if this was a CNC lathe and it let me push the tool past the axis limits?
Otherwise if I wanted to set my X minimum below zero, should I just use the offset of the tool furthest to the left?
This is my config/geometry
Axes Min Max X 0 303 Y -7 300 Z 0 600
Tools origin/offset carriage (0, 0, 0) tool0 (15.1, 0, -24.35) tool1 (15.30, 0.8, -24.16)
Please post your actual config.g file using the </> tag
Thanks.
