    (Resume print after shutdown power)
    Using Duet Controllers
    • Rodrigue Richalland
      Rodrigue Richalland last edited by
      I want to know if it's possible to resume a print after a shutdown power ? If yes, how ?
      If it's unpossible, does a system exist to use an inverter with a digital input to inform the board of the power switching ? which will allow to cut heatbed or other heavy devices for exemple.
      Thank you so much,
      Rodrigue 😁
      • T3P3Tony
        https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure
        So sure how up to date that one is so also check:
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M916_Resume_print_after_power_failure
        If you have something that will give the Duet advanced warning of power failure then you can use that to switch and input pin, tied to a trigger, to run a macro which could turn off the bed etc then pause the print.
        www.duet3d.com
          Thanks for your reply. It's little bit complexe for me but i nothing is unpossible !
