    Paneldue 5i Blown?
    Firmware installation
    • Davidcgoodwin01
      Davidcgoodwin01 last edited by
      I connected the screen on a Duet 2 Wifi board and it worked perfectly. Now connecting it to the Duet 3 on the io_0 port with cable adjustments as needed and firmware I think correct the screen does not turn on as in no power. Connecting to the PC via USB is the same result...but there had been no incidents so I am at a loss for why it is doing what it is doing.
      M575 P1 S1 B57600 ; enable support for PanelDue - io_0 is what I am using .
      • Veti
        Veti last edited by
        did you accidentally hit the erase button?
        • Davidcgoodwin01
          I intentionally hit the erase button a couple of times, but BOSSA cant see the comport.
            If you look into the bottom edge of the display where the flexible PCB disappears into a slot in the metal, can you see the backlight LED lighting up?
            • Davidcgoodwin01
              There is no LED lighting up when plugging it into the PC.
                Try a different cable and usb port?
