    Duet Wifi Motors wont work after update to RRF3
    Firmware installation
    399
    • AndiG85undefined
      AndiG85
      Hi I am new to this community and after many hours of trying to fix my problem on my own I landed here to ask for your expertise:
      I upgraded to RRF3 lately and cant get my Motors to work. Maybe its an obvious problem but i cant figure it out.
      Here is my config file:
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Mar 02 2021 20:27:45 GMT+0100 (Mitteleuropäische Normalzeit)
      M550 P"Angryprint V2" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      ; --- z-axis stepper leveling configuration ---
      M671 X-50:-50:370:370 Y330:-65:-65:330 S20 ; Z belts at 4 corners
      ; --- drive map ---
      ; _______
      ; | 6 | 7 |
      ; | 5 | 8 |
      ; front
      Drives
      M569 P0 S1 ; X goes forwards
      M569 P1 S1 ; Y goes forwards
      M569 P2 R-1
      M569 P3 S1 ; Extruder goes forwards
      M569 P4 R-1
      M569 P5 S1 ; Z1 goes forwards
      M569 P6 S0 ; Z2 goes backwards
      M569 P7 S1 ; Z3 goes forwards
      M569 P8 S0
      M569 P9 R-1
      M584 X0 Y1 E3 Z6:5:8:7 ; set drive mapping
      M92 X80 Y80 Z400 E716 ; set steps per mm
      M566 X900.00 Y900.00 Z20.00 E1000 ; set maximum instantaneous speed changes (mm/min)
      M203 X20000.00 Y20000.00 Z1000.00 E3600.00 ; set maximum speeds (mm/min)
      M201 X2500.00 Y2500.00 Z500.00 E1800.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E500 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X5 Y-5 Z0 S1 ; set axis minima
      M208 X310 Y308 Z410 S0 ; set axis maxima
      M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
      M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P9 C"^zprobe.in" H5 F600 T9000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y21 Z1.95 ; set Z probe trigger value, offset and trigger height
      M557 X10:300 Y21:300 S55 ; define mesh grid
      M143 H0 S130 ; set temperature limit for heater 0 to 130C
      M143 H1 S320 ; set temperature limit for heater 1 to 320C
      M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2 ; create chamber heater output on e1heat and map it to sensor 2
      M307 H2 B1 S1.00 ; enable bang-bang mode for the chamber heater and set PWM limit
      M141 H2 ; map chamber to heater 2
      M143 H2 S60 ; set temperature limit for heater 2 to 60C
      M106 P1 S1 H1:2 T45 ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q0 ; create fan 2 on pin fan2 and set its frequency
      M950 F3 C"duex.fan7" Q500
      M950 F4 C"duex.fan8" Q500
      M106 P1 S1 H1:2 T45
      ; --LED--
      M950 P5 C"duex.fan4" Q500
      M42 P5 S255
      M950 P6 C"duex.fan5" Q500
      M42 P6 S255
      M950 P7 C"duex.fan6" Q500
      M42 P7 S255
      M563 P0 S"Mosquito" D0 H1 F0 ; define tool 0
      ; Custom settings
      ; --- drive map ---
      ; _______
      ; | 6 | 7 |
      ; | 5 | 8 |
      ; front
      T0 ; select first tool
      The Error:
      Warning: motor phase A may be disconnected reported by driver(s) 0 1
      Warning: motor phase B may be disconnected reported by driver(s) 0 1
      Can someone help me?
      • fcwiltundefined
        fcwilt
        One thing you may find helpful is to execute from the DWC console M98 P"config.g".
        This will display any status messages of interest including error messages that you won't see during power on.
        Also what firmware version are you running?
        • AndiG85undefined
          AndiG85
          Hi Frederick,
          thank you for this hint. I'm currently running RRF 3.2.2 but I upgraded to 3.0 first
          Andi
            @AndiG85 said in Duet Wifi Motors wont work after update to RRF3:
            Well that error would indicate that there may be a bad connection on drivers 0 and 1. So double check your wiring.
            As a quick test you could connect the motors from another axis, like 2 of the Z motors to X and Y and see if it gives the same error. If it does, that may mean the problem is with the driver itself.
            Can you also provide the results of sending M122?
            Were you up and running before updating to RRF3?
            • AndiG85undefined
              AndiG85
              Before the update it was running just fine on 2.05
              I didn't touch anything of the wiring at all
              I just tried to plug in 2 of the z-motos into X and Y but the problem remains the same.
              M122.txt
              • AndiG85undefined
                AndiG85
                4.3.2021, 07:04:53 Warning: motor phase A may be disconnected reported by driver(s) 0 1
                4.3.2021, 07:04:49 Warning: motor phase A may be disconnected reported by driver(s) 0 1
                4.3.2021, 07:04:45 Warning: motor phase A may be disconnected reported by driver(s) 0 1
                4.3.2021, 07:04:41 M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later + DueX5
                Board ID: 08DJM-9178L-L4MSN-6JKF4-3SJ6Q-1932R
                Used output buffers: 1 of 24 (24 max)
                Static ram: 23460
                Dynamic ram: 74488 of which 60 recycled
                Never used RAM 14072, free system stack 119 words
                Tasks: NETWORK(ready,180) HEAT(blocked,308) DUEX(blocked,31) MAIN(running,451) IDLE(ready,20)
                Owned mutexes: WiFi(NETWORK)
                Last reset 00:00:31 ago, cause: power up
                Last software reset at 2021-03-03 21:49, reason: User, GCodes spinning, available RAM 13996, slot 1
                Error status: 0x00
                Aux0 errors 0,0,0
                MCU temperature: min 28.2, current 29.1, max 29.2
                Supply voltage: min 24.0, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 0: position 0, open-load-A, open-load-B, SG min/max not available
                Driver 1: position 0, ok, SG min/max not available
                Driver 2: position 2000, temperature-shutdown! short-to-ground, standstill, SG min/max not available
                Driver 4: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
                Driver 5: position 0, standstill, SG min/max not available
                Driver 6: position 0, standstill, SG min/max not available
                Driver 7: position 0, standstill, SG min/max not available
                Driver 8: position 0, standstill, SG min/max not available
                Driver 9: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
                Driver 10: position 0
                Driver 11: position 0
                Date/time: 2021-03-04 07:04:41
                Cache data hit count 22518687
                Slowest loop: 13.92ms; fastest: 0.29ms
                === Storage ===
                Free file entries: 9
                SD card longest read time 2.4ms, write time 0.0ms, max retries 0
                DMs created 83, maxWait 25368ms, bed compensation in use: none, comp offset 0.000
                === MainDDARing ===
                Scheduled moves 2, completed moves 1, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                === AuxDDARing ===
                Bed heaters = 0 -1 -1 -1, chamberHeaters = 2 -1 -1 -1
                Heater 1 is on, I-accum = 0.0
                Segments left: 0
                Movement lock held by HTTP
                HTTP is idle in state(s) 1 8, running macro
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                Daemon is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 201.99ms; fastest: 0.09ms
                HTTP sessions: 1 of 8
                • WiFi -
                  Network state is active
                  Failed messages: pending 0, notready 0, noresp 1
                  WiFi firmware version 1.23
                  WiFi MAC address c8:2b:96:00:73:b7
                  WiFi Vcc 3.38, reset reason Power up
                  WiFi flash size 4194304, free heap 25272
                  WiFi IP address 192.168.1.62
                  WiFi signal strength -51dBm, mode none, reconnections 0, sleep mode modem
                  Clock register ffffffff
                  === DueX ===
                  Read count 0, 0.00 reads/min
                  Phaedrux Moderator @AndiG85
                  Well that's a pretty good range of errors in there. If you're really sure it has nothing to do with wiring and nothing other than the firmware update has happened you could simply try to revert back to the previous firmware version.
                  If you still have access to DWC. Upload the zip file for 2.05.1 in the system tab. Don't extract it first. Reboot after. Use M115 to verify the firmware has been applied.
                  If you still have your config.g from RRF2 you can upload that as well.
                  If the errors are now resolved that would be an interesting result. You could then try updating to 3.0 and then 3.2.2 again by uploading those zip files in the same way and see what happens.
                  https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                  https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
                  • AndiG85undefined
                    AndiG85
                    Ok..
                    I went back to 2.05 and everything was fine again.
                    I updated to 3.0 and now it works.
                    It is the same config file.
                    Thank You very much for your help 🙂
                    Andi
                      Did you update to 3.2.2 as well?
                      • Kaot93undefined
                        Kaot93
                        Hello Everyone,
                        are there any news on this topic?
                        I have the exact same problem with my duet 2 with CustomDuex attached, and I'm getting the same errors regarding the steppermotors.
                        Everything works fine with 2.05. After editing the Config.g for the new conditions of RRF3 it works with 3.0 aswell. But everything after 3.0 doesn't work.
                        Best regards,
                        Basti
                        dc42undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                          dc42 administrators @Kaot93
                          @kaot93 please explain exactly what you mean by "same errors" and "doesn't work", and post your config.g file.
                            Phaedrux Moderator @Kaot93
                            @kaot93 said in Duet Wifi Motors wont work after update to RRF3:
                            CustomDuex
                            What is customduex?
