    Duet 3 Mini 5+ connections problems
    415
    • dk_tommytundefined
      dk_tommyt
      Hi.
      I got a new Duet 3 Mini 5+.
      i cant get it to make connection to my pc so that i can configurate it.
      i have tried 4 computers
      6 usb cabel.
      when i put the usb cabel in the duet the 3v and 5v led light near reset button / power usb up but nothing happens in device management
      it wont show up in device manager.
      i have followed
      https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
      can you help me ?
      • T3P3Tonyundefined
        T3P3Tony administrators
        when you plug the board in with the USB cable to a PC, try double clicking the reset button. you will see the diag light change to slow pulsing. The board should show up as a storage device. this will show if the USB cable/port is working or not.
        www.duet3d.com
          dk_tommyt
          hi.
          Nothing happens when i press the reset button ?
          tried 4 cables and 3 usb ports
          greetings
          tommy
          • chrishammundefined
            chrishamm administrators @dk_tommyt
            @dk_tommyt You must press it twice in short succession, then the diag LED will start pulsing.
            Duet software engineer
              dk_tommyt
              hi.
              Nothing happens when i double clicking the reset button
              i have presst it twice meany times and nothing happens
              grettings
              tommy
                Can you go through this?
                https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
                What LEDs light up on the board when connected to USB?
                • T3P3Tonyundefined
                  @dk_tommyt is the diag light on at all when powered over USB?
                  www.duet3d.com
                    dk_tommyt
                    Hi.
                    i got a video of what happens on power on and when i press the reset button
                    https://youtu.be/YOGZNTowwMc
                    grettings
                    tommy
                      Can you try with the SD card removed?
                      It was hard to see in the video which LEDs exactly are lit.
                      dk_tommytundefined 1 Reply Last reply Reply Quote 0
                        dk_tommyt @Phaedrux
                        @Phaedrux
                        https://youtu.be/k5vH9-jUoQ0
                        it is the same whiteout sdcard.
                        it is 3v and 5v
                          Please contact your vendor and initiate a warranty exchange. Include a link to this thread as authorization.
                            dk_tommyt
                            hi.
                            will do.
                            thanks for the help.
                            grettings
                            tommy
