Solved Slice hot end heater and HT thermistor help
trying to configure my hot end and thermistor but can't fathom it out, anyone shed some light on it guys?
mini5 with slice HT thermistor and 50w heater
I changed the syntax M308 S1 P"1.temp1" and it disabled the heater, I since changed it back to bthe below but still disabled.
; HotEnd Heaters and Thermistor HotEnd
M308 S1 P"temp1" Y"thermistor" T500000 C1.196220e-7 ;define E0 temperature sensor Slice
M950 H1 C"1.out1" T1 ; Create HotEnd Heater
M307 H1 R2.277 C166.5:115.4 D6.87 S1.00 V22.9 B0 ; Hotend PID new version
M143 H1 S285 ; Set temperature limit for heater 1 to 285C HotEnd
M302 S185 R185 -
For the others: He's using a Duet 3 Mini 5+ in SBC mode.
I see one error there.
Don't know where the 1 is coming from.
M950 H1 C"out1" T1 ; Create HotEnd Heater
is the right output name.
I would also post the whole config.g and put a "code" tag around it.
; General preferences G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Network M550 P"Pruset II MK3s" ; Set machine name M552 S1 ; Enable network ;*** Access point is configured manually via M587 M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet M575 P1 S1 B57600 ; Panel Due ; Drive Mappings M569 P0.0 S1 V0 ; Drive 0 goes forwards: X Axis M569 P0.1 S0 V0 ; Drive 1 goes backwards: Y Axis M569 P0.2 S1 V0 ; Drive 2 goes backwards: Z Axis M569 P0.3 S1 V0 ; Drive 3 goes forwards: E Axis M569 P0.4 S1 V0 ; Drive 4 goes backwards: Z Axis (at E1) ; Micrpstepping and Speed M350 X16 Y16 E16 Z16 I1 ; Configure microstepping with interpolation M92 X200.00 Y200.00 Z400.00 E830.00 ; Set steps per mm ; Speeds, Acceleration and Jerk M566 X240.00 Y240.00 Z24.00 E270.00 P1 ; Set maximum instantaneous speed changes (mm/min) M203 X7200.00 Y7200.00 Z723.00 E1200.00 ; Set maximum speeds (mm/min) M201 X1250.00 Y1250.00 Z1000.00 E500.00 ; Set accelerations (mm/s^2) M204 P1250.0 T1250.0 ; set print and travel accelerations (mm(s^2) ; Motor currents M906 X1000.00 Y1100.00 Z600.00 E700.00 I10 ; Set motor currents (mA) and motor idle factor in percent M84 S30 ; Set idle timeout ; Motor remapping for dual Z and axis Limits M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1 M671 X-37:287 Y0:0 S10 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis ; Printer geometry M208 X0:250 Y-4:215 Z-0.5:205 ; X carriage moves from 0 to 250, Y bed goes from 0 to 210 M564 H0 ; allow unhomed movement ; Endstops for each Axis M574 X1 S3 ; Set endstops controlled by motor load detection M574 Y1 S3 ; Set endstops controlled by motor load detection ; Stallgaurd Sensitivy M915 X S-10 F0 H400 R0 ; Set X axis Sensitivity ;working 3.3 M915 Y S-10 F0 H400 R0 ; Set y axis Sensitivity ; woring 3.3 ; Input Shaper M593 F60 P4 S0.2 ; Input Shaping ; Z-Probe Super PINDA M574 Z1 S2 ; Set endstops controlled by probe M558 P5 C"^io3.in" I1 H1 F500 T4800 A30 S0.004 ; PINDA ; Probing Mesh Grid and Sheets M557 X24:221 Y10:195 P8 ; Define mesh grid for probing G31 P1000 X23 Y5 Z1.585 ; Textured Sheet ;G31 P1000 X23 Y5 Z1.280 ; PEI ; Heatbed Heaters and Thermistor Bed M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.060000e-8 ; Set thermistor + ADC parameters for heater 0 Bed M950 H0 C"out0" T0 Q100 ; Creates Bed Heater M307 H0 R0.238 C254.1 D10.82 S1.00 V22.9 B0 ; Bed PID new version M140 H0 ; Bed uses Heater 0 M143 H0 S120 ; Set temperature limit for heater 0 to 120C Bed ; HotEnd Heaters and Thermistor HotEnd M308 S1 P"1.temp0" Y"thermistor" T500000 C1.196220e-7 ;define E0 temperature sensor Slice M950 H1 C"1.out1" T1 ; Create HotEnd Heater M307 H1 R2.277 C166.5:115.4 D6.87 S1.00 V22.9 B0 ; Hotend PID new version M143 H1 S285 ; Set temperature limit for heater 1 to 285C HotEnd M302 S185 R185 ; Fans M950 F1 C"out5" Q250 ; Creates HOTEND Fan M106 P1 T45 S235 H1 ; HOTEND Fan Settings M950 F0 C"out6" Q100 ; Creates PARTS COOLING FAN M106 P0 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off PARTS COOLING FAN ; Tools M563 P0 D0 H1 F0 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C G91 G1 X1 Y1 Z1 G90 M83 M98 P"0:/macros/02_Functions/StartupFilamentSensorCheck" ; Runout Sensor Logic: Startup with filament = runout sensor active Startup without filament = autoload active
; HotEnd Heaters and Thermistor HotEnd M308 S1 P"temp1" Y"thermistor" T500000 B4723 C1.19622e-7 ;define E0 temperature sensor Slice HT M950 H1 C"out1" T1 ; Create HotEnd Heater M307 H1 R2.277 C166.5:115.4 D6.87 S1.00 V22.9 B0 ; Hotend PID new version M143 H1 S285 ; Set temperature limit for heater 1 to 285C HotEnd M302 S185 R185
made a couple of amendments got heater back, deleted the trailing 0 from "C" and the errors went away but still -273 temp
@Argo said in Slice hot end heater and HT thermistor help:
The leading number targets the can address of the board it's connected to in cases where you have expansion boards. 0 is the mainboard and then each canbus board after goes up by 1.
https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_Num_3
Just as a sanity check this is what the configurator produces for a mini5 and slice thermistor.
M308 S1 P"temp1" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C
Which looks the same as yours but maybe copy and paste it into yours to replace it in case there's some funky characters in there or something.
@Phaedrux I see, thanks for clarification.
Turns out it was a bad cable with it's brand new Slice Engineering thermistor and not an issue with the config.
