    One axis will not calibrate
    362
    • thunderboltcutterundefined
      thunderboltcutter
      For some reason my Y axis will not respond to changes in the config.g file. When I print a calibration cube that side always comes out the same. The board is being used in a Solidoodle 4 with stock stepper motors.
      Phaedruxundefined 1 Reply Last reply Reply Quote 1
      • fcwiltundefined
        fcwilt
        Please post your config.g file using the </> tag.
        Also tell us what board you are using and what firmware version.
        Thanks.
          thunderboltcutter
          ; Configuration file for Duet WiFi (firmware version 2.00)
          ; generated by RepRapFirmware Configuration Tool v3.2.2 on Mon Feb 01 2021 20:16:34 GMT-0500 (Eastern Standard Time)
          M550 P"SD4" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S1 ; enable FTP
          M586 P2 S1 ; enable Telnet
          M350 Z16 I0 ; configure microstepping without interpolation
          M350 X16 Y16 E16 I1 ; configure microstepping with interpolation
          M92 X90.36 Y88.78 Z2151.90 E415.00 ; set steps per mm
          M566 X1000.00 Y1000.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X2000.00 Y2000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z1000.00 E250.00 ; set accelerations (mm/s^2)
          M906 X1050 Y1000 Z1050 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S5 ; Set idle timeout
          M208 X203 Y203 Z203 S0 ; set axis maxima
          M574 X2 Y2 Z1 S1 ; set active high endstops
          M558 P5 H5 F0 T6000 ; set Z probe type to switch and the dive height + speeds
          G31 P0 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
          M557 X15:203 Y15:203 S20 ; define mesh grid
          M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
          M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
          M143 H1 S285 ; set temperature limit for heater 1 to 285C
          M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S1 I0 F500 H1 T23 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M106 P2 S1 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
          ; Custom settings
          M564 H0
          • fcwiltundefined
            fcwilt
            I've re-posted your config.g file using the </> tag as requested.
            thunderboltcutter Mar 19, 2021, 2:58 PM
            ; Custom settings
            M564 H0
              thunderboltcutter
              Thank you!
              • fcwiltundefined
                fcwilt
                I don't see anything obvious there.
                From the DWC console execute M122 and post the results.
                Also execute M98 P"config.g" and let us know if there are any warnings or errors reported.
                Thanks.
                  thunderboltcutter
                  I am getting a spam error when trying to post M122 output to the forum. Is there a work around?
                  fcwiltundefined 1 Reply Last reply Reply Quote 1
                  • fcwiltundefined
                    fcwilt @thunderboltcutter
                    @thunderboltcutter said in One axis will not calibrate:
                    Change the file extension to .g perhaps?
                    thunderboltcutterundefined 1 Reply Last reply Reply Quote 0
                      thunderboltcutter @fcwilt
                      @fcwilt
                      I am going break things up into a few posts to see what's getting caught by the filter.
                      ~~M98 P"config.g"
                      HTTP is enabled on port 80
                      FTP is enabled on port 21
                      TELNET is enabled on port 23~~
                        thunderboltcutter
                        M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later
                        Board ID: 08DLM-996RU-N85S4-7JTDL-3SN6R-1S9VR
                        Used output buffers: 1 of 20 (19 max)
                        Static ram: 28380
                        Dynamic ram: 95820 of which 0 recycled
                        Exception stack ram used: 420
                        Never used ram: 6452
                        Task NETWORK ready, free stack 324
                        Task HEAT blocked, free stack 1256
                        Task MAIN running, free stack 3624
                          Phaedrux Moderator @thunderboltcutter
                          What exactly does this mean? I'm not sure what you're describing. Photo of the results? What are you expecting to happen? What are you trying to change?
                            I've given you a few upvotes, so hopefully it won't bug you about spam as much. Might also help to take a pause for 10 minutes and try and create a single post again with all the copy and paste. Multiple posts in rapid succession is likely to trigger it.
                            • fcwiltundefined
                              fcwilt @Phaedrux
                              @Phaedrux said in One axis will not calibrate:
                              I learn something new everyday.
                                thunderboltcutter
                                No matter what I do with the y axis variable when printing a calibration cube I get 20.55mm from that side.
                                Using setting like this yields the same results:
                                M92 X90.36 Y91.0 Z2151.90
                                M122
                                Static ram: 28380
                                Last reset 05:29:33 ago, cause: power up
                                Last software reset at 2021-03-18 20:25, reason: User, spinning module GCodes, available RAM 6588 bytes (slot 3)
                                Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
                                Error status: 0
                                Free file entries: 10
                                MCU temperature: min 25.5, current 25.5, max 25.8
                                Supply voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0, over voltage events: 0
                                Date/time: 2021-03-19 15:06:44
                                Slowest loop: 7.60ms; fastest: 0.08ms
                                Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                                Scheduled moves: 0, completed moves: 0
                                Bed compensation in use: none
                                Heater 0 is on, I-accum = 0.8
                                Heater 1 is on, I-accum = 0.4
                                Segments left: 0
                                Movement lock held by null
                                http is ready with "M122 " in state(s) 0
                                telnet is idle in state(s) 0
                                file is idle in state(s) 0
                                serial is idle in state(s) 0
                                aux is idle in state(s) 0
                                daemon is idle in state(s) 0
                                queue is idle in state(s) 0
                                Code queue is empty.
                                === Network ===
                                Slowest loop: 200.85ms; fastest: 0.01ms
                                HTTP sessions: 2 of 8
                                - WiFi -
                                Network state is running
                                Failed messages: pending 3, notready 0, noresp 3
                                WiFi firmware version 1.25
                                WiFi MAC address f4:cf:a2:69:48:de
                                WiFi Vcc 3.33, reset reason Turned on by main processor
                                WiFi flash size 4194304, free heap 23104
                                WiFi IP address 192.168.1.82
                                WiFi signal strength -56dBm, reconnections 0, sleep mode unknown
                                === Expansion ===
                                • fcwiltundefined
                                  Where did you get those values? They are a bit unusual.
                                  Perhaps you could restore the X and Y values to the theoretical values and using...
                                  M579 X1.0 Y1.0 Z1.0 ; scaling (values are determined by measuring test object)
                                  to scale the size of the objects printed? Values of 1.0, as shown, produce no scaling.
                                    Phaedrux Moderator @fcwilt
                                    @fcwilt said in One axis will not calibrate:
                                    Looks like the solid doodle uses MXL belts and 17 tooth pulleys for an approximate steps per mm of 88.
                                    http://www.soliforum.com/topic/2671/solidoodle-belt-and-pulley-specs-belt-replacement-guide/page/2/
                                    https://tomhorsley.com/hardware/solidoodle/solidoodle-calibration.html
                                    Can I get you to update your firmware?
                                    Upload this zip file to the system tab in DWC.
                                    Don't extract it first.
                                    • fcwiltundefined
                                      fcwilt @Phaedrux
                                      Never heard of MXL belts or 17 tooth pulleys - new facts to stuff into my old brain.
                                      One thing I don't quite understand is why the X and Y steps/mm (whatever they actually should be) would in practice be different.
                                      What is the source of the variation between X and Y?
                                      Thanks.
                                        Well Solid Doodle made some funny choices. (MXL, 17 tooth, etc) so who knows what else is funky in there. Product of the times I suppose.
                                        As for why they would be so different here in this case and why the steps per mm isn't having an effect, I wonder if it's something mechanical. Slippage or something. Loose grub screw?
