2nd print problem
I migrated my "End G-Code" and "Start G-Code" from the slicer to the "start.g" and "stop.g". But I have a problem with the 2nd print now. (Same g-code file) The printer zHome, levels the bed, heats up the bed, set the temperature but do not turn on the heater. So the extruder tries cold extrusion which is obviously not wanted. What do I do wrong here?
(I had a M98 P"0:/sys/start.g" in the start gcode. but that resulted in a "double home" etc, so I think it works at all.)
Start g code in the slicer:
; Nothing here
Stop g-code
; End print here, that will call stop.g M0
start.g
; Turn on LED M106 P3 S255 G28 ; Home G1 Z15 F5000 ; lift nozzle G29 S1 ; Load the height map
stop.g
M400 ; Finish move queue ;Retract the filament G92 E1 G1 E-0.5 F300 G92 E2 G1 E-0.5 F300 ;M106 S255 ; Fan at 100 to cool nozzle and bed G91 ; Relative positioning M220 S100 ; Set speed factor back to 100% in case it was changed M221 S100 ; Set extrusion factor back to 100% in case it was changed G1 Z15 ; raise nozzle 15mm from printed part G90 ; Absolute position G1 Y255 F3000 ; Bring the Bed to the front M106 P3 S0 ; Turn LED off
The gcode file starts with
M107 M190 S75 ; set bed temperature and wait for it to be reached G10 S225 ; set temperature ;TYPE:Custom ;M98 P"0:/sys/start.g" G10 S225 ; set temperature M116 ; wait for temperature to be reached G21 ; set units to millimeters G90 ; use absolute coordinates M82 ; use absolute distances for extrusion G92 E0 ; Filament gcode ;LAYER_CHANGE ;Z:0.21 ;HEIGHT:0.21 G1 Z0.210 F7800.000 ; Turn LED down if layer = 5 ; Turn LED off if layer = 10 G1 E-2.00000 F2400.000 G92 E0 G1 X66.121 Y82.954 F7800.000 G1 E2.00000 F2400.000 ;TYPE:Skirt ;WIDTH:0.42 G1 F1800.000 G1 X67.158 Y82.235 E2.03964 G1 X67.995 Y81.802 E2.06926 G1 X68.874 Y81.462 E2.09889
And ends with:
;WIDTH:0.471686 G1 F1200.000 G1 X72.703 Y90.715 E2.03106 G1 X72.788 Y91.336 F7800.000 ;WIDTH:0.685842 G1 F1200.000 G1 X72.788 Y94.363 E2.18638 G1 X72.441 Y94.715 F7800.000 G1 F1200.000 G1 X69.467 Y94.715 E2.33902 G1 E0.33902 F2400.000 G92 E0 M107 ;TYPE:Custom ; Filament-specific end gcode ;END gcode for filament ; End print here, that will call stop.g M0
I do not get the reason that the heater is "off" and them temp is correct at the 2nd print.
Cheers, Chriss
@Chriss
I guess you need a tool select in your start.g -
I'm not sure, I select the T0 in my config.g and I do not change the tool afterwards. (At least not yet.)
And the tools seems to be selected because I see that the "active" temp is changed.
Cheers, Chriss
@Chriss
Yes but I think M0 is deactivating the tool
Edir:
The config.g is only read once at boot -
Yep, that is clear that the config.g is parsed at boot only. So there is no way that I do not have no tool selected when I have a "T0" in the config.g. And as I wrote: The T0 tries to cold extrude. How can you cold extrude at a tool if you have no tool selected?
@Chriss said in 2nd print problem:
Edit complained that I did not read your mail carefully enough. The M0 does not deselect the tool. It turns the heater off:
If no H1 parameter is present, the heaters are turned off too.
I need to change the start.g to turn the heat back on. I will test that....
Cheers, Chriss
You where absolutely right. I added a "T0" to the start.g and it seems to work now. I have to test that in one or two other conditions but I think that this did it.
But this behavior is not fully logical to me or I did not understood the docu correctly:
https://duet3d.dozuki.com/Wiki/Gcode#Section_M0_Stop_or_Unconditional_stopThe bulletpoint 4 tells me that it turns the heater off. In my world would the "G10 S225" also turn on the heater. I know that there is a other command for that but Prusa does what Prusa does.
Cheers, Chriss
One potential problem with using start.g as opposed to using M98 in the slicer is that start.g happens before any slicer code whereas the M98 invoked code happens later.
How much later depends on the slicer in use and certain slicer settings.
For my slicer I cannot use start.g because the commands I wish to execute get overridden by slicer generated code. Using M98 works because the slicer happens to execute the M98 after those same commands so my commands override the slicer commands - which works fine.
Yes, that was the reason that I posted the head of the g-code:
You can see the two lines which start with ";", that is the "start gcode" in the slicer. Well, the two "G10" around the start g-code is a bit confusing but PS does what PS does.
The start.g comes before all of that. Anyway, the observed behavior is gone but it is still not logical to me. My understanding was that you can not "deselect" a tool. But exactly that seems to happen with "M0". :?
Cheers, Chriss
@Chriss This may help. This is what I use in the start gcode in PrusaSlicer:
T-1 ; deselect current tool
M98 P"/macros/PLAOffset" ; set z probe offsets
G10 P0 S[first_layer_temperature] R140 ; set T0 temps
M190 S[first_layer_bed_temperature] ; heat up bed
G28 ; home all axes
G32 ; bed calibration
T0 ; select T0 and heat to active temp
M116 ; wait for temp on T0
G1 E10 ; extrude a bitConfig.g has a T0 at the ends of the file.
Macro PLAOffset contains the G31 settings. -
Depending on what you want to do you may need to use start.g as well as the slicer start gcode section and even call a separate macro with M98.
In this case the heaters being off means the tool is deselected. G10 S225 will only set the temperature, but won't activate any tools. So yes you need T0 in your start.g to re-select the tool, at which point any temperatures that have been set will begin to heat.
