RFF 3.22 Bl Touch Error
I upgraded my ender 5+ to DuetWifi running stable 3.22 I have the bl touch hooked up into the correct positions, I have tried 3 sets of cables and 2 Bl Touch 3.1. I keep getting
Error:M280: invalid servo index 0 in m280 Command
It seems that it is not setup right but my code looks correct as far as i can see. i used the official configuration tool.
; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Mar 19 2021 22:22:19 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"EnderEXO5+" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P3 S0 ; physical drive 3 goes backwards
M92 X80.00 Y80.00 Z4000.00 E409.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X360 Y360 Z410 S0 ; set axis maxima; Endstops
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop; Z-Probe
G31 P500 X-51 Y15.75 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X50:300 Y50:300 S25 ; define mesh grid; Heaters
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
M950 F2 C"fan1" Q500 ; create fan 2 on pin fan1 and set its frequency
M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power lossM280 P0 S10 ; deploy BLTouch
M280 P0 S90 ; retract BLTouch -
Can you please send M122 and M98 P"config.g" in the console and post the results?
Please post the contents of deployprobe.g and retractprobe.g from the system tab.
Test that M401 and M402 deploy and retract the probe.
thanks to you i was able to find that the firmware was all messed up after doing fresh install of 3.22 it is working now, it was stuck in part 2.05 and 3.22 i guess
If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
That will get your firmware and DWC up to date.
