    IDEX Markforged Home All issue
    • buttonundefined
      button
      Hi!
      I just after month my printer with dual marforged kinematic (IDEX).
      Problem that I have is at homing all axis.
      I can home all axis separetly, and behavior is correct. When I hit home all i have error:
      "Error: G0/G1: insufficient axes homed"
      My files for me looks really ok:
      homeX:
      G91              ; relative positioning
      G1 H2 Z5 F2400   ; lift Z relative to current position
      G1 H1 X-340 F3000 ; move quickly to X axis endstop and stop there (first pass)
      G1 X5 F6000  ; go back a few mm
      G1 H1 X-340 F300  ; move slowly to X axis endstop once more (second pass)
      G1 H2 Z-5 F2400  ; lower Z again
      G90              ; absolute positioning
      HomeU:
      G1 H1 U340 F3000 ; move quickly to Y axis endstop and stop there (first pass)
      G1 U-5 F6000  ; go back a few mm
      G1 H1 U340 F300  ; move slowly to Y axis endstop once more (second pass)
      HomeY:
      G1 H1 Y340 F3000 ; move quickly to Y axis endstop and stop there (first pass)
      G1 Y-5 F6000  ; go back a few mm
      G1 H1 Y340 F300  ; move slowly to Y axis endstop once more (second pass)
      HomeZ:
      G1 H1 Z-300 F600 ; move Z down until the endstop is triggered
      G1 H2 Z3 F2400
      G1 H1 Z-300 F180
      G90
      G1 Z5 F1200
      And finaly HOMEALL:
      G1 H1 X-340 U340 F3000 		; move quickly to X and U axis endstops and stop there (first pass)
      G1 X5 U-5 F6000 			; odbicie X i U
      G1 H1 X-340 U340 F300 		; powrot wolno XU
      G1 H1 Y340 F3000
      G1 H1 Y340 F300  			; move slowly to X and Y axis endstops once more (second pass)
      G1 Y-320 F4800
      G1 H1 Z-300 F600      		; move Z down stopping at the endstop
      G1 H2 Z3 F2400
      G1 H1 Z-300 F180
      G1 Z5 F1200					; lift Z
      I can't figure out whats wrong here...
      • fcwiltundefined
        fcwilt
        If may be because you are trying to home X and U at the same time.
        Try doing them individually.
        If that doesn't work you could use "brute force" and comment out lines 4 to 14 and test.
        If all is good un-comment the next line and test again.
        Eventually you should find the line causing the problem.
        If you don't mind a bit of inefficiency you can use my approach.
        For you it would look like this:
        M98 P"homeZ.g"
        M98 P"homeX.g"
        M98 P"homeU.g"
        M98 P"homeY.g"
          dc42 administrators @fcwilt
          @fcwilt said in IDEX Markforged Home All issue:
          That's correct. You should be able to do a first pass homing X and U together, and both axes should stop when the first endstop is triggered. Then you need to home X and U separately. It's the same as for homing a CoreXY printer, see https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_homeall_g_file.
          fcwiltundefined 1 Reply Last reply Reply Quote 2
          • fcwiltundefined
            fcwilt @dc42
            @dc42 said in IDEX Markforged Home All issue:
            Thanks for the confirmation.
            • buttonundefined
              button
              Did homing separate - working great. THX
