Duet 2 Wifi: wifi no longer works
Hello everyone.
I need help with the wifi on my card that has stopped working.
The card is a Duet 2 Wifi rev 1.04c with integrated antenna purchased in January with the original 3.2 firmware on the card.
I used the config tool and the wifi connected correctly. I had access to the web interface and the printer responded correctly.This morning the machine would not connect. The blue diode was not lit anymore.
After a few tests that did not give anything, I thought that the files on the SD card might be corrupted.
It turned out that the SD card was dead without me understanding why.So I changed it and copied the backup from the previous card.
I launch the printer and... it still doesn't work.So I redid the configuration with the config tool by putting the information of my wifi. Still the same. No wifi diode and of course no connection.
I connected my PC in USB and I did M115 followed by M122 which gave me that:
M115 FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.2 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-01-05 ok M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later Board ID: 0JD0M-9P6B2-NJ4S8-6JKD4-3SD6Q-9U7AL Used output buffers: 1 of 24 (1 max) === RTOS === Static ram: 23460 Dynamic ram: 73112 of which 12 recycled Never used RAM 15496, free system stack 184 words Tasks: NETWORK(ready,521) HEAT(blocked,323) MAIN(running,442) IDLE(ready,19) Owned mutexes: USB(MAIN) === Platform === Last reset 00:32:27 ago, cause: power up Last software reset details not available Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 52.0, current 59.6, max 59.9 Supply voltage: min 0.1, current 0.4, max 0.6, under voltage events: 0, over voltage events: 0, power good: no Driver 0: position 0, ok, SG min/max not available Driver 1: position 0, ok, SG min/max not available Driver 2: position 0, ok, SG min/max not available Driver 3: position 0, ok, SG min/max not available Driver 4: position 0, ok, SG min/max not available Driver 5: position 0 Driver 6: position 0 Driver 7: position 0 Driver 8: position 0 Driver 9: position 0 Driver 10: position 0 Driver 11: position 0 Date/time: 1970-01-01 00:00:00 Cache data hit count 2621479119 Slowest loop: 100.93ms; fastest: 0.14ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 0.4ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is ready with "M122" in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 0.22ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 0 of 8 - WiFi - Network state is starting2 WiFi module is disabled Failed messages: pending 0, notready 1, noresp 0 Socket states: 0 0 0 0 0 0 0 0 ok
Since wifi is noted as disabled I tried an "M552 S1" and got this message:
M552 S1 "Turn off the current WiFi mode before selecting a new one ok"
I tried to redo the manipulations of the first connection tutorial but nothing works.
I tried to make a M558 S "*" and I got the following message:
M558 S"*" "Error: M588: Failed to reset the WiFi module to factory settings: another SPI transfer is pending"
I tried all the manipulations I found in the different topics but nothing works.
I'm lost.
What can I do? -
Try sending these network commands
M552 S-1 M552 S0 M552 S1 M997 S1 M588 S"*" M587 M587 S"ABC" P"password"
@tahi also try reflashing the WiFi firmware with M997 S1.
Hello and thank you for your answers.
I tried the manipulations and here is the result:
M552 S-1 WiFi module stopped ok M552 S0 ok M552 S1 Turn off the current WiFi mode before selecting a new one ok M997 S1 T0:-273.1 /0.0 B:-273.1 /0.0 Trying to connect at 230400 baud: failed Trying to connect at 115200 baud: failed Trying to connect at 74880 baud: failed Trying to connect at 9600 baud: failed Error: Installation failed due to comm write error ok
I'm starting to wonder if the wifi module might be down.
Yes I think that may be the case.
Where did you purchase the Duet Wifi in January? If from an authorized reseller, please contact them and initiate a warranty exchange. Include a link to this forum thread as authorization.
