    Primacreator P120 + Duet Wifi
    • baesjerker
      baesjerker last edited by
      Hi. I have a spare Duet 2 WiFi laying around. The stock board on my primacreator P120 died.
      I do not know much about wattage, amps and so on, but I know how to connect/wire everything.
      Would it be possible to use my spare Duet 2 WiFi with the original power cord? It’s rated at 12V 7A.
      Thanks
        Phaedrux Moderator @baesjerker last edited by
        Maybe some photos of what you mean?
        Power cord? Or Power supply? If the power supply from the Primacreator outputs 12v it should work.
        See here for some more details on power supply choice.
        https://duet3d.dozuki.com/Wiki/Choosing_the_power_supply
        baesjerker 1 Reply Last reply Reply Quote 0
        • baesjerker
          baesjerker @Phaedrux last edited by
          @phaedrux sorry about that. Yes I meant power supply. This is my only printer with a lookalike laptop charger. My biggest concern is the amperage. 7 A.
            7A is a bit low, but kind of depends on what hardware you're trying to run with it. Is this the same power supply that comes with the printer stock? Do you know the wattage of the extruder and bed heaters?
            If this PSU was used with the stock printer and you haven't changed any of the other hardware then it should still work.
