    DUEX 5 Error: short-to-ground reported by driver(s) 6
    56
    • KEVINIANFIELD
      KEVINIANFIELD last edited by
      my dueX 5 expantion board has a error on driver 6. if I unplug the expantion board the duet wifi will operate nornmal but when I plug the expantion board back in I get this error.
      Error: over temperature shutdown reported by driver(s) 6
      please advise if this is normal ?
      07/04/2021, 18:57:41 M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later + DueX5
      Board ID: 0JD0M-9P6M2-NW4SN-6JKD2-3S86L-9BTML
      Used output buffers: 3 of 24 (8 max)
      Static ram: 25712
      Dynamic ram: 94640 of which 0 recycled
      Exception stack ram used: 272
      Never used ram: 10448
      Tasks: NETWORK(ready,676) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3736) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:01:00 ago, cause: power up
      Last software reset at 2021-04-07 18:46, reason: User, spinning module GCodes, available RAM 10028 bytes (slot 1)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 10
      MCU temperature: min 14.8, current 18.7, max 18.9
      Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 5: standstill, SG min/max not available
      Driver 6: temperature-shutdown! short-to-ground standstill, SG min/max not available
      Driver 7: standstill, SG min/max not available
      Driver 8: standstill, SG min/max not available
      Driver 9: standstill, SG min/max not available
      Date/time: 2021-04-07 18:57:40
      Cache data hit count 173250001
      Slowest loop: 5.86ms; fastest: 0.07ms
        How does driver 6 look?
        Is there a motor connected to it?
        Is this a new Duex? Or was it working before?
        KEVINIANFIELD 2 Replies Last reply Reply Quote 0
          dc42 administrators @KEVINIANFIELD last edited by dc42
          Is the driver 6 chip getting hot?
          KEVINIANFIELD 1 Reply Last reply Reply Quote 0
          • KEVINIANFIELD
            KEVINIANFIELD @Phaedrux last edited by
            @phaedrux ![alt text](thumbnail_Image.jpg image url) The board is new and there is no motor connected yet.
            • KEVINIANFIELD
              KEVINIANFIELD @dc42 last edited by
              @dc42 the driver chip does not warm up.
              • KEVINIANFIELD
                @phaedrux driver 7 looks has no writing on it is that normal ?
                  It looks like it's still there faintly. Perhaps got rubbed off in cleaning the board?
                  Can you get a close up of driver 6 with better lighting?
                  When and where did you purchase the Duex?
                  • KEVINIANFIELD
                    @phaedrux I bought this board from E3D last month 8/3/21.
                      Please contact E3D and initiate a warranty exchange. Include a link to this thread as authorization.
                      • KEVINIANFIELD
                        @phaedrux cool thanks 🙂
