    6HC path to 48v motors
    1
    179
    • gallaghersart
      gallaghersart last edited by
      Per previous posts, hope I got correct. https://forum.duet3d.com/topic/13958/duet-3-32v-on-3d-printer
      6HC and 3HC can use different volts from each other. (in same system)
      Mentions of hacking boards to get higher voltages means problems with 5v and 12v.
      If my 3HC is only used for X and Y motors, could I modify my 3HC to use 36v or even 48v?
      All sensors / fans / end stops etc.. would be from the 6HC.
      Other option is 6HC + (1x) 1XD per axis along with “CNC style” separate drivers then motors.
      Thanks!
      `mike
