    3.3b3 1LC toolboard sync LED sometimes blinks fast
    Beta Firmware
    1
    1
    84
    • oliofundefined
      oliof
      my new toolboard generally works well, but I sometimes observe that the sync LED is blinking fast rather slow during printing. Here is an M122:
      M122 B10
      Diagnostics for board 10:
      Duet TOOL1LC firmware version 3.3beta3 (2021-04-21 20:42:51)
      Bootloader ID: not available
      Never used RAM 3880, free system stack 0 words
      Tasks: Move(notifyWait,6.7%,91) HEAT(delaying,32.7%,81) CanAsync(notifyWait,0.0%,58) CanRecv(notifyWait,3.2%,77) CanClock(notifyWait,3.4%,66) TMC(delaying,522.7%,57) MAIN(running,887.9%,347) AIN(delaying,903.2%,62), total 2360.0%
      Last reset 27:01:44 ago, cause: software
      Last software reset data not available
      Driver 0: position 13205188, 420.0 steps/mm, ok, SG min/max 0/82, read errors 0, write errors 0, ifcnt 70, reads 46490, writes 9, timeouts 0, DMA errors 0, steps req 15557346 done 15557104
      Moves scheduled 93890, completed 93889, in progress 1, hiccups 0, step errors 0, maxPrep 731, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
      Peak sync jitter 10, peak Rx sync delay 227, resyncs 166, next step interrupt due in 1032 ticks, enabled
      VIN: 23.8V
      MCU temperature: min 27.4C, current 43.8C, max 61.1C
      Ticks since heat task active 198, ADC conversions started 97115662, completed 97115661, timed out 0, errs 0
      Last sensors broadcast 0x00000002 found 1 203 ticks ago, loop time 0
      CAN messages queued 1106478, send timeouts 0, received 905968, lost 0, free buffers 36, min 34, error reg 0
      dup 0, oos 0, bm 0, wbm 0
      Accelerometer detected: no
      I2C bus errors 4619, naks 4619, other errors 4619
      Is this expected? Printing completed without issue.
