    [3.3-rc1] Strange error on PanelDue
    Beta Firmware
    • PaulHew
      PaulHew last edited by
      Since upgrading to 3.3-rc1 I get an error on my console.
      Was not there running the 3.3 b3
      Regards,
      Paul.
      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
        dc42 administrators @PaulHew last edited by
        @paulhew do you get this message frequently? Or once on start up? If you get it frequently, does anything in particular trigger it?
        Please post your config.g file.
        PaulHew 1 Reply Last reply Reply Quote 0
        • PaulHew
          PaulHew @dc42 last edited by
          @dc42 As requested
          G90                                              ; send absolute coordinates...
          M83                                              ; ...but relative extruder moves
          M550 P"RailCoreII"                              ; set printer name
          M669 K1                                          ; select CoreXY mode
          G4 S1											 ; wait for expansion boards to start
          M569 P0.0 S1                                     ; X Axis - physical drive 0.0 goes forwards
          M569 P0.1 S0                                     ; Y Axis - physical drive 0.1 goes backwards
          M569 P0.2 S1                                     ; Left Front physical drive 0.2 goes forwards
          M569 P0.3 S1                                     ; Left Rear physical drive 0.3 goes forwards
          M569 P0.4 S1                                     ; Right physical drive 0.4 goes forwards
          M569 P20.0 S0                                    ; Extruder - physical drive 20.0 goes forwards
          M584 X0.0 Y0.1 Z0.2:0.3:0.4 E20.0                ; set drive mapping
          M350 X16 Y16 Z16 E16 I1                          ; configure microstepping with interpolation
          M92 X200.00 Y200.00                                ; set steps per mm
          M92 Z1600                                        ; set steps per mm Z Axis
          M92 E412                                         ; set steps per mm Extruder
          M566 X600.00 Y600.00 Z200.00 E3600.00            ; set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z900.00 E3600.00          ; set maximum speeds (mm/min)
          M201 X1500.00 Y1500.00 Z250.00 E1500.00          ; set accelerations (mm/s^2)
          M906 X1280 Y1280 Z1220 E700 I30                  ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                          ; Set idle timeout
          ; Leadscrew locations
          ;New 4-2-21
          M671 X-1:-1:350 Y24:281:151 S7.5
          ;M208 X0 Y0 Z0 S1                                 ; set axis minima
          ;M208 X230 Y300 Z400 S0                           ; set axis maxima
          M208 X-10:300 Y0:300 Z-0.5:500 S0
          M574 X1 S1 P"io5.in"                             ; configure active-high endstop for low end on X via pin io5.in
          M574 Y1 S1 P"20.io2.in"                          ; configure active-high endstop for low end on Y via pin 20.io1.in
          ; Z-Probe - ToolBoard 1LC
          M950 S0 C"20.io0.out"                           ; create servo pin 0 for BLTouch
          M558 P9 C"^20.io0.in" H5 F120 T6000             ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X-7 Y35 Z0.904                            ; set Z probe trigger value, offset and trigger height
          ;M557 X15:215 Y15:195 S20                         ; define mesh grid
          M557 X30:280 Y45:280 S20
          ; Z-Probe - Using io_1
          ;M950 S0 C"io1.out"                           ; create servo pin 0 for BLTouch
          ;M558 P9 C"^io1.in" H5 F120 T6000             ; set Z probe type to bltouch and the dive height + speeds
          ;G31 P500 X-7 Y35 Z2.5                            ; set Z probe trigger value, offset and trigger height
          M308 S0 P"temp0" Y"thermistor" A"Heated Bed" T100000 B4138     ; configure sensor 0 as thermistor on pin temp0
          M950 H0 C"out0" T0                               ; create bed heater output on out1 and map it to sensor 0
          ;M307 H0 B0 S1.00                                 ; disable bang-bang mode for the bed heater and set PWM limit
          M307 H0 R0.853 C250.9 D5.98 S0.60                ; tuned to 50degrees - 28/3/21
          M140 H0                                          ; map heated bed to heater 0
          M143 H0 S120                                     ; set temperature limit for heater 0 to 120C
          M308 S1 P"20.temp0" Y"thermistor" A"Mosquito" T500000 B4723 C1.19622e-7; configure sensor 1 as thermistor on pin 20.temp0
          M950 H1 C"20.out0" T1                           ; create nozzle heater output on 20.out0 and map it to sensor 1
          ;M307 H1 B0 S1.00                                 ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S280                                     ; set temperature limit for heater 1 to 280C
          ;M307 H1 R1.632 C237.7 D6.86 S1.00 V24.2
          M307 H1 B0 R1.480 C221.2:201.5 D7.80 S1.00 V24.0
          ; Other Thermistors
          M308 S2 P"temp1" Y"thermistor" A"Bed-Top" T100000 B4138     ; configure sensor 0 as thermistor on pin temp0
          M308 S3 P"20.temp1" Y"thermistor" A"Chamber" T100000 B4138
          M950 F0 C"20.out1+out1.tach" Q500                         ; create fan 0 on pin 20.out1 and set its frequency
          M106 P0 S0 H-1                                   ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"20.out2" Q500                         ; create fan 1 on pin 20.out2 and set its frequency
          M106 P1 S1 H1 T50                                ; set fan 1 value. Thermostatic control is turned on
          M563 P0 D0 H1 F0                                 ; define tool 0
          G10 P0 X0 Y0 Z0                                  ; set tool 0 axis offsets
          G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
          ;Lights
          M950 F10 C"out1"
          M106 P10 S0 H-1 C"Front Lights"
          M106 P10 S1
          M150 X1 Q3000000                                 ; Configure NeoPixel channel
          M150 R000 b000 u000 P128 S60                     ; Turn them all off if on
          M575 P1 S1 B57600                                ; enable support for PanelDue
          T0					                             ; select first hot end
          Regards
          Paul
          • PaulHew
            PaulHew @PaulHew last edited by
            Does not happen when printer is booted from power off
            Duet Mini 5+ and SBC
            Saw it when it started a print, will see if the error comes up again.
            • PaulHew
              Just homed the printer, bed was about 150mm down, XY ok and after Z a new message appeared on the PanelDue.
              m122
              RepRapFirmware for Duet 3 Mini 5+ version 3.3RC1 (2021-05-01 09:59:28) running on Duet 3 Mini5plus Ethernet (SBC mode)
              Board ID: A45XG-F396U-D65J0-40KML-1F03Z-H03XP
              m122 b20
              Diagnostics for board 20:
              Duet TOOL1LC firmware version 3.3beta2+1 (2021-04-07 10:51:19)
              Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
              Regards,
              Paul
