    Using a Display Encoder to Forward Filament
    1
    97
    • Topherundefined
      Topher
      Im working on a script for loading filament and trying to see if I can integrate the Fysetc display encoder wheel. Once the filament has been moved a set amount to get it a few mm from the extruder, I want to use the encoder wheel to forward the filament step by step; as the wheel is being turned it should move the filament - similar to how the alter command functions with movement on XYZUW axis with this menu button function:
