DuetWiFiFirmware minor release 1.15d
    I'm recently back from two weeks holiday, so able to work on firmware again. The next major release will be 1.16, but in the interim and in response to posts on this forum, I have released firmware 1.15d with the following changes:
    • Reduce incidence of false heating fault alarms, in particular "temperature rising much more slowly than the expected 0.0C"
    • Stepper drivers beyond the first 5 are now assumed not to be TMC2660 drivers, so the Enable signal is used as a driver enable instead of a chip select
    It's available at https://github.com/dc42/RepRapFirmware/tree/dev/Release/Duet-WiFi. There is no change needed to DuetWiFiServer or DuetWebControl for this release.
