Duet 3 6hc - sd card Cannot initialise SD
Hi, I have a problem with duo 3 6 hc v1.01 in standalone mode. It worked properly, today after the start the paneldue showed "connecting", RJ45 network does not turn on. Can't see the configuration.
After diagnostics via USB:
SENDING: M21
Error: M21: Cannot initialise SD card 0: Card is unusable
[ERROR] Error: M21: Cannot initialise SD card 0: Card is unusableConnecting...
Printer is now online.
m115
SENDING:M115
FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.3RC2 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-05-11 14:55:28SENDING:M122
RepRapFirmware for Duet 3 MB6HC version 3.3RC2 (2021-05-11 14:55:28) running on Duet 3 MB6HC v1.01 or later (standalone mode)
Board ID: 08DJM-956L2-G43S8-6J9D4-3S46Q-TU2GD
Used output buffers: 1 of 40 (1 max)
Static ram: 150680
Dynamic ram: 90376 of which 464 recycled
Never used RAM 112672, free system stack 200 words
Tasks: NETWORK(ready,7.6%,548) HEAT(delaying,0.0%,387) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,945) CanSender(notifyWait,0.0%,373) CanClock(notifyWait,0.0%,343) TMC(notifyWait,0.0%,105) MAIN(running,72.8%,1272) IDLE(ready,19.5%,29), total 100.0%
Owned mutexes: USB(MAIN)
Last reset 00:00:30 ago, cause: power up
Last software reset details not available
Error status: 0x00
[ERROR] Error status: 0x00Aux0 errors 0,0,0
Aux1 errors 0,0,0
Step timer max interval 120
MCU temperature: min 27.9, current 30.0, max 30.1
Supply voltage: min 0.4, current 0.4, max 0.5, under voltage events: 0, over voltage events: 0, power good: no
12V rail voltage: min 0.1, current 0.1, max 0.2, under voltage events: 0
Driver 0: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
Driver 1: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
Driver 2: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
Driver 3: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
Driver 4: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
Driver 5: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
Slowest loop: 0.09ms; fastest: 0.05ms
=== Storage ===
Free file entries: 10
SD card 0 detected, interface speed: 0.2MBytes/sec
=== MainDDARing ===
=== AuxDDARing ===
Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is ready with "M122" in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== CAN ===
Messages queued 150, send timeouts 149, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49)
Last cancelled message type 30 dest 127
=== Network ===
Slowest loop: 0.08ms; fastest: 0.00ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
HTTP sessions: 0 of 8- Ethernet -
State: disabled
Error counts: 0 0 0 0 0
[ERROR] Error counts: 0 0 0 0 0
two memory cards the same. Correctly formatted, nothing has changed. Tried updating via usb. no change.
Do you have ideas if the board is defective to be replaced under warranty? purchased from an official Polish reseller
after pressing the card:
m21
SENDING:M21
SDHC card mounted in slot 0, capacity 31.91Gbsocket soldering or faulty card socket
- Ethernet -
This post is deleted! -
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
