    WiFi reported error: no known networks found
    Firmware installation
    • Raffa2s
      Raffa2s last edited by
      In the last few days, I had tried to connect to my Duet2 wifi as always but I couldn't (server unreachable). I had tried to reset the firmware but nothing... How can I fix that?
      Down below you can find the state of M587 and M552 S1, after that the error "WiFi reported error: no known networks found" even if the wifi is listed.
      Send: M587
      Recv: Remembered networks:
      Recv: CASARAF IP=192.168.1.29 GW=0.0.0.0 NM=0.0.0.0
      Recv: ok
      Send: M552 S1
      Recv: ok
      Recv: WiFi reported error: no known networks found
      Recv: WiFi module is idle
      thank you
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @Raffa2s last edited by
        @raffa2s the SSID is case sensitive. Is your wifi network name all in capitals?
        What terminal software did you use?
        Owns various duet boards and is the main wiki maintainer for the Teamgloomy LPC/STM32F4 port of RRF
        Raffa2s 1 Reply Last reply Reply Quote 0
        • Raffa2s
          Raffa2s @jay_s_uk last edited by
          @jay_s_uk I just write it right but it's appears like that, is it normal?
          Octoprint as terminal was used
          • jay_s_uk
            @raffa2s I believe octoprint capitalises every letter. So if you have anything lowercase in your password or SSID you need to use ' in front of each letter as described here https://duet3d.dozuki.com/Wiki/Gcode#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
            If you're reading the same network I suggest starting a fresh by deleting all known networks using M588 S"*"
            • Raffa2s
              @jay_s_uk ok I try
