    Fail to read my position while using G1 H3
    • agusano
      agusano last edited by
      Hello everyone, I'm using the sensorless homing for the X axis.
      On my GCode routine, once I've done the homing process and the position is stored to 0 (forced by the G92 X0 code) I would like to move that axis till the opposite and with the G1 H3 parameter stop the movement and store my new position.
      Once I use this H3 gcode parameter, my Duet 2 allows me to move along the axis but ignores the real position of the machine, but it never stores to the new position o in the case I home the axis again it never turns back to 0. Can someone help me?
      Thanks in advance
        dc42 administrators @agusano last edited by
        @agusano you should not be using G92 X0 after the homing move. A G1 H1 move will set the position to the limit you have set in M208.
        After the G1 H3 move completes, you should be able to read the position from move.axes[0].userPosition or move.axes[0].machinePosition.
        agusano 1 Reply Last reply Reply Quote 0
          Post your config.g and homing files.
          • agusano
            agusano @dc42 last edited by
            @dc42 Thank you for your response. I've found that my problem was related to my fw version so it does'nt work properly. Now i read my position without any problem, but i would like to know if it is possible to read the position from one axis neither than from all the axis as the M114 does. Thank you!
              @agusano said in Fail to read my position while using G1 H3:
              Yes, you can report the position to console like this:
              echo move.axes[0].userPosition
