    SOLVED X-Axis is homing the wrong direction
    • InfidelProps
      InfidelProps last edited by
      Hi all... First, I'm loving this new Duet board and how easy it is to update config... never going back to marlin!
      Pre-requisites:
      • Ender 5 Plus with OEM mechanical switches (Cartesian geometry)
      • Y-Switch is on the back right side of my printer
      • X-Switch is on the right side of the printer
      • RepRap 3.2.3 (Latest Stable)
      • DWC is 3.2.2
      My problem is that while my Y-axis homes correctly, my X-Axis homes incorrectly and goes to the opposite side of my printer.
      Config.g - Relevant Sections
      M569 P0 S1
      M569 P1 S1
      M569 P2 S1
      M569 P3 S1
      M208 X0 Y0 Z0 S1
      M208 X350 Y350 Z400 S0
      M574 X1 S1 P"xstop"
      M574 Y1 S1 P"ystop"
      M574 Z1 S2
      Homey.g File
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Jun 05 2021 07:45:40 GMT+1000 (Australian Eastern Standard Time)
      G91               ; relative positioning
      G1 H2 Z5 F6000    ; lift Z relative to current position
      G1 H1 Y-355 F1800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 H2 Y5 F6000    ; go back a few mm
      G1 H1 Y-355 F360  ; move slowly to Y axis endstop once more (second pass)
      G1 H2 Z-5 F6000   ; lower Z again
      G90               ; absolute positioning
      homex.g gile
      G1 H1 X-355 F1800 ; move quickly to X axis endstop and stop there (first pass)
      G1 H2 X5 F6000    ; go back a few mm
      G1 H1 X-355 F360  ; move slowly to X axis endstop once more (second pass)
      And here's the output of M208
      Axis limits X0.0:350.0, Y0.0:350.0, Z0.0:400.0
      I did try to invert my Y with adding the M574 Y1 S1 P"!ystop" in the config file, and while it moves the motor in the correct position, it moves about 1-5mm and then stops and says it's at 0.
      Still reading through other posts, but wanted to add my notes here just in case someone spots a misconfiguration somewhere.
      Thanks!
      2x Ender 5 Plus's - Microswiss Hotend - Duet 2 Wifi // Peopoly Phenom
      InfidelProps 1 Reply Last reply Reply Quote 0
      • InfidelProps
        InfidelProps @InfidelProps last edited by
        @infidelprops So as I've been investigating this.. When I manully trigger the Y-stop, the LED goes completely off.
        But when I manually trigger the X-stop, the LED is still light lit up...
        When I move the X by 10mm, the Dashboard says it's at 10, but the M119 command is telling me the x is at min stop Endstops - X: at min stop, Y: not stopped, Z: at min stop, Z probe: at min stop
        Another weird issue...
        With the x-stop is not depressed, M119 reports X: at min stop even though X is at Position 10
        But when I press the mechanical switch, it says X: not stopped
        • InfidelProps
          Looks like a lose connector in my pin was the culprit... the light being left on was a good indicator.
          When I tried to pull the connector out, the wire came free so I put on a new molex connector on and plugged back in... all working as expected now
