    Pinda2 to Duet3 toolboard
    607
    • martin7404
      martin7404 last edited by martin7404
      EDIT: I1 and pullup removed from code
      I spent an hour or so reading the different posts to find how to wire and set Pinda2 probe on the tool board v1.1 of my new CoreXY machine. So here is some info for others to use. This will work for other inductive sensors, just do not connect temp1 connector
      Wiring
      Configuration
      M671 X-31.39:250:531.36 Y18:433.3:18 S10       ; Locations left, center, right
      M558 P8 C"121.io2.in"  H0.7 F1000 T6000 A20 S0.005 ; PINDA set Z probe type to switch and the dive height + speeds
      M308 S2 P"121.temp1" A"PINDA" Y"thermistor" T100000 B3950
      G31 P500 X-3.20 Y0 Z2.5                                    ; set Z probe trigger value, offset and trigger height
      M557 X20:485 Y41:360 P7                             ; define mesh grid
      Here is the probe repeatability test result
      6/6/2021, 9:26:30 AM	G32 bed probe heights: -0.001 -0.003 -0.003 -0.002 -0.002 -0.003 -0.002 -0.003 -0.002 -0.003 -0.001 -0.003 -0.003 -0.003 -0.002 -0.002 -0.001 -0.001 -0.002 -0.001 -0.000 -0.001 -0.002 -0.002 -0.002, mean -0.002, deviation from mean 0.001
      Muldex IDEX 3d printer Duet2+Duex5+Paneldue 7i
      Custom CoreXY 600x400 Hemera , Duet3+toolboard v1.1, Paneldue 7i
      Mod Sapphire Pro with Duet2 ,Expansion Board with closed-loop motors
      voron v0.1 and cr10s both running klipper; stock Bambu lab X1CC
      dc42 droftarts 2 Replies Last reply Reply Quote 2
        dc42 administrators @martin7404 last edited by
        @martin7404 thanks for sharing this.
        • droftarts
          droftarts administrators @martin7404 last edited by
          @martin7404 said in Pinda2 to Duet3 toolboard:
          M558 P8 C"^121.io2.in" I1 H0.7 F1000 T6000 A20 S0.005 ; PINDA set Z probe type to switch and the dive height + speeds
          Small error in the above: in RRF 3, the 'I1' to invert the probe signal is deprecated and this parameter is being ignored. So the probe signal is not being inverted. See https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_in_RepRapFirmware_Num_3
          dc42 1 Reply Last reply Reply Quote 1
            dc42 administrators @droftarts last edited by
            @droftarts said in Pinda2 to Duet3 toolboard:
            Also, the ^ pullup enable should not be used on Duet 3 IOx_in ports..
            oc_geek droftarts 2 Replies Last reply Reply Quote 0
            • oc_geek
              oc_geek @dc42 last edited by
              @dc42 said in Pinda2 to Duet3 toolboard:
              Could you please elaborate a bit more on this, why is that ?
              ...and does "Duet3" do include Mini variants ?
              Thanks
              • droftarts
                droftarts administrators @dc42 last edited by
                Bah, always forget that one!
                • droftarts
                  droftarts administrators @oc_geek last edited by
                  modules:composer.user_said_in, @oc_geek, Pinda2 to Duet3 toolboard
                  The pullup resistor (internal to the MCU, so not something we can remove) never needs to be enabled when using Duet 3 IOx.IN pins, and doing so worsens the noise margin.
                  Yes.
                  • oc_geek
                    oc_geek last edited by oc_geek
                    i find my end-stops (hall effect) work much better with ^ rather then without
                    If i remove ^ i get false triggers... so this appears a bit strange tbh..
                    @droftarts
                    droftarts martin7404 2 Replies Last reply Reply Quote 0
                    • droftarts
                      @oc_geek on Duet 3 Mini 5+? @dc42 do you have a view on this?
                      • martin7404
                        martin7404 @oc_geek last edited by martin7404
                        @oc_geek same story I tried and i gives me false triggers on Pinda 2 too
                        EDIT
                        I did the first tests without cycling power, after a power cycle, now it works ok without Pullup
                        • martin7404
                          @dc42 I still do not know if using ^ will damage my duet3
                          Phaedrux dc42 2 Replies Last reply Reply Quote 0
                            Phaedrux Moderator @martin7404 last edited by
                            @martin7404 No I don't think it will damage the board. I think the worst case is just lowering the noise floor. But it seems to work BETTER for you?
                              No it won't.
                              • martin7404
                                TO warp up
                                In the end I found that it is working both ways with or without pullup.
                                I ended up changing pinda2 to superpinda, as far I got one delivered and super panda is working flawlessly with the same config
                                kb58 1 Reply Last reply Reply Quote 1
                                • kb58
                                  kb58 @martin7404 last edited by
                                  @martin7404 Just curious, where were you able to purchase a superPinda? Prusa only sells them to registered owners. Asking because I would like to get one as well.
                                  Scratch-built 350mmx350mm coreXY, linear rails, ballscrews, 3 Z axis, Duet3 6HC, v3.3, Tool Board v1.1, BondTech LGX + Mosquito hot end
                                  martin7404 1 Reply Last reply Reply Quote 0
                                  • martin7404
                                    martin7404 @kb58 last edited by martin7404
                                    @kb58 prusa online shop, I have mk3 printer. You can always ask somebody local for you with original prusa to order 1 for you
                                    • Sn1kk3r5
                                      Sn1kk3r5 last edited by
                                      Hi there,
                                      I wonder if I can connect a original Prusa Super Pinda the same way the pinda 2 is connected?
                                      The Super Pinda has only 3 wires instead of four (white is missing).
                                      I assume this is based on temperature independence now.
                                      One thing in addition, does anyone know if the Super Pinda uses 5v only? I read a couple thing like 5v-24v and the higher the more accurate it should be.... is this a rumor, or proofed?
                                      Thanks in advance.
                                      Cheers
                                      • martin7404
                                        martin7404 @Sn1kk3r5 last edited by martin7404
                                        @sn1kk3r5 I switched to superpinda and it works. Just ignore the white wire on my drawing in first post
                                        • Sn1kk3r5
                                          Thanks @martin7404
