    How to home (G28) midprint and resume?
    Gcode meta commands
    98
    • lazy_mosquito
      lazy_mosquito last edited by
      I want to do a colorchange with my duet 0.85 in the middle of a print. I can pause at the right place, but because i have a rather big delta printer with a fidly filament change it is almost impossible to change my filament without moving the printhead. My solution was to insert a G28 command after the break in the g-code; so it would center it again before resuming print. but after the g28 command it homes indeed but stops and tells me the print is finished. Somebody another idea how i can rehome my head again after filament change in midprint?
        What firmware version?
        What do you have in homedelta.g?
        What do you have in pause.g and resume.g?
        lazy_mosquito 1 Reply Last reply Reply Quote 0
        • lazy_mosquito
          lazy_mosquito @Phaedrux last edited by
          @phaedrux
          RepRapFirmware for Duet 1.26.1 (2020-02-09b1)
          homedelta.g:
          G91 ; relative positioning
          ;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
          G1 S1 X1305 Y1305 Z1305 F3600 ; move all towers to the high end stopping at the endstops (first pass)
          G1 S2 X-5 Y-5 Z-5 F1800 ; go down a few mm
          ;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
          G1 S1 X10 Y10 Z10 F180 ; move all towers up once more (second pass)
          G1 Z-5 F2400 ; move down a few mm so that the nozzle can be centred
          G90 ; absolute positioning
          G1 X0 Y0 F3600 ; move X+Y to the centre
          no pause.g
          no resume.g
            I'm not sure how exactly it will behave when pause and resume macros are missing. But this is what the config tool generates for pause and resume for a delta. It saves the current print position and then parks and then resume will restore that print position.
            ; pause.g
            ; called when a print from SD card is paused
            ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jun 08 2021 13:01:27 GMT-0600 (Central Standard Time)
            M83            ; relative extruder moves
            G1 E-10 F3600  ; retract 10mm of filament
            G1 Z5 F360     ; lift Z by 5mm
            G1 X0 Y0 F6000 ; go to X=0 Y=0
            ; resume.g
            ; called before a print from SD card is resumed
            ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jun 08 2021 13:01:50 GMT-0600 (Central Standard Time)
            G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
            G1 R1 X0 Y0          ; go back to the last print move
            G1 E10 F3600         ; extrude 10mm of filament
            You can make adjustments to that if you wish as well.
            • lazy_mosquito
              lazy_mosquito @Phaedrux last edited by lazy_mosquito
              @phaedrux
              This would work in a normal situation, it works on my Prusa. But on the Prusa it is very easy to change the filament without moving the printhead, which is almost impossible with my delta printer.
              The problem is, that the printer will restore its position from the existing,moved, coordinates, but when the head is moved by replacing the filament, the printer has lost its absolute position and will go back to the wrong position, that's why I would like to home it first. In that way, I can reposition the head back in a known position and start from there.
              My printer has rods of 72 cm, which makes that any force you put on the arms easily overpowers the holding force of the steppermotors, specially with my extruder. It works very well but is a pain to load new filament.
                Phaedrux Moderator @lazy_mosquito last edited by
                @lazy_mosquito said in How to home (G28) midprint and resume?:
                Yes I understand. Add a G28 to the resume macro.
                • lazy_mosquito
                  @phaedrux
                  Thanks already for your answer.
                  I would expect it behaves similarly to adding it directly in the code.
                  But I will first try to invoke it via the pause and the resume macro and sees if it makes a difference instead of invoking it directly in the g-code.
                  i just create the macro's and invoke them manually after the prints pauses?
                    No, when you create a pause.g and resume.g macro file in the /sys folder they will get called when you manually pause and resume the print with the buttons automatically.
                    o_lampe 1 Reply Last reply Reply Quote 0
                    • o_lampe
                      o_lampe @Phaedrux last edited by
                      @phaedrux
                      I'm not aware that RRF 1.26 already had the 'restore position' feature?
                      @lazy_mosquito
                      Can you add a bracket to the printer frame (bed respectively) were you park&lock the effector before filament change?
                      lazy_mosquito Phaedrux dc42 3 Replies Last reply Reply Quote 0
                      • lazy_mosquito
                        lazy_mosquito @o_lampe last edited by
                        @lazy_mosquito
                        Thats an option i was also thinking about, but more complex to achieve compared to code.
                          Phaedrux Moderator @o_lampe last edited by
                          @o_lampe said in How to home (G28) midprint and resume?:
                          Ah yes, I hadn't thought about that. I'll have to dig to see when that was implemented. I took it for granted that it was already present.
                            dc42 administrators @o_lampe last edited by
                            The restore position feature was introduced in 2014 AFAIR, several years before rrf 1.26 was released.
