Sherpa mini on RRF
Hello, was wondering had sameone used sherpa mini with rrf? Recently bought one and trying to configure it.
What's the question? shouldn't be anything unique to rrf about it
@luke-slaboratory
I mean values in config.g. Like teps per mm, acceleration and so on -
@judgment_kazzy
https://github.com/Annex-Engineering/Sherpa_Mini-Extruder/blob/master/Klipper_Config_Block.txt# Extruder0 [extruder] rotation_distance: 22.67895 #for 5mm Shaft Driven Bondtech gearsets #gear_ratio: 50:10 #for standard 10t motor gear_ratio: 50:8 #for sherpa mini 8t motor microsteps: 16 full_steps_per_rotation: 200 #1.8deg Motor max_extrude_only_distance: 1400.0 max_extrude_only_velocity: 75.0 max_extrude_only_accel: 1500 #settings for NEMA14 Stepper [tmc2209 extruder] interpolate: True #Run current is listed in RMS run_current: 0.30 #min current, equivalent to 0.42A peak (Peak = RMS/0.707) #run_current: 0.35 #max current, equivalent to 0.49A peak (Peak = RMS/0.707)
https://github.com/KevinOConnor/klipper/blob/master/docs/Rotation_Distance.md
rotation_distance = <full_steps_per_rotation> * <microsteps> / <steps_per_mm>
solve for steps/mm, and then multiply by the gear ratio listed.
@luke-slaboratory said in Sherpa mini on RRF:
@judgment_kazzy
I get 705.5 steps/mm for the 10T
@Judgment_Kazzy
I started using it, but with a different motor (ACT 36HS2418). I use 710 steps/mm and 60mm/s retraction speed. All other settings like jerk and accel aren't tuned yet, but my findings will be irrelevant anyway for use with the standard LDO motor.
