Z Axis not homing endstops Ender 3
Dear Duet3D team
I want to ask for your help to set correctly the setup of my Z axis in my Ender 3 using the Duet3D Mini 5
Preconditions:
- The Ender 3 was working correctly before with the IR Probe from Duet installed in Z axis.
- I have removed from the board the IR Probe because I have installed the Bondtech extruder DDXv3 and at the moment I dont have the option to install the IR probe in the new setup
- I have now the original config.g as was before without the IR Probe to use the original mechanical endswitch from the Ender 3 for the Z Axis.
The problem:
When I homing all the Axis, the Z is going up 5mm and I can read that the new tool position for my Z it is set to 0. If I try again the Z is going again 5mm up and the tool position for the Z is again in 0.
The Z axis is not moving to the stop end switch, just the X and Y is moving correctly to the home position where the end stop switch are.
I dont have errors reported by the system in the console. I did try multiple configurations with G92 Z0 and 91 relative and absolute position and other options but still my Z axis just going up 5mm and declared the new tool position as 0 when in reality is probably 25 mm up from the bed.
I have removed the option in Homeall.g for G1 H2 Z5 F6000 and this help to stop moving the Z axis the 5mm up, but still the problem to find the way how the Z axis is not travelling to the home position where the endstop switch is originally.
Here is my config.g
; Configuration file for Duet 3 Mini 5+ (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jun 22 2021 17:40:51 GMT+0200 (Mitteleuropäische Sommerzeit) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Printer" ; set printer name ; Network M551 P"1970" ; set password M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S0 ; physical drive 0.0 goes backwards M569 P0.1 S0 ; physical drive 0.1 goes backwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P0.3 S0 ; physical drive 0.3 goes backwards M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z600.00 E3600.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z200.00 E2500.00 ; set accelerations (mm/s^2) M906 X600 Y600 Z600 E900 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X235 Y235 Z260 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io5.in" ; configure active-high endstop for low end on X via pin io5.in M574 Y1 S1 P"io6.in" ; configure active-high endstop for low end on Y via pin io6.in M574 Z1 S1 P"io2.in" ; configure active-high endstop for low end on Z via pin io2.in ; Z-Probe M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X20:200 Y20:200 S10 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S90 ; set temperature limit for heater 0 to 90C M308 S1 P"temp1" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency M106 P0 C"PartCool" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency M106 P1 C"HotEnd" S1 H1:0 T45 ; set fan 1 name and value. Thermostatic control is turned on M950 F2 C"out5" Q500 ; create fan 2 on pin out5 and set its frequency M106 P2 C"CaseFan" S1 H1:0 T45 ; set fan 2 name and value. Thermostatic control is turned on ; Tools M563 P0 S"Hotend" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool
Here is my Homeall.g
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jun 22 2021 17:40:51 GMT+0200 (Mitteleuropäische Sommerzeit) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-240 Y-240 F1800 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y5 F6000 ; go back a few mm G1 H1 X-240 Y-240 F360 ; move slowly to X and Y axis endstops once more (second pass) G1 H1 Z-255 F6000 ; move Z down stopping at the endstop G92 Z0 ; set Z position to axis minimum (you may want to adjust this) G90 ; absolute positioning G1 X120 Y120 F6000 ; position probe at center of bed ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
My homex.g
; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jun 22 2021 17:40:51 GMT+0200 (Mitteleuropäische Sommerzeit) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-240 F1800 ; move quickly to X axis endstop and stop there (first pass) G1 H2 X5 F6000 ; go back a few mm G1 H1 X-240 F360 ; move slowly to X axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
My homey.g
; homey.g ; called to home the Y axis ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jun 22 2021 17:40:51 GMT+0200 (Mitteleuropäische Sommerzeit) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 Y-240 F1800 ; move quickly to Y axis endstop and stop there (first pass) G1 H2 Y5 F6000 ; go back a few mm G1 H1 Y-240 F360 ; move slowly to Y axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
My homez.g
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jun 22 2021 17:40:51 GMT+0200 (Mitteleuropäische Sommerzeit) G91 ; relative positioning G1 H2 Z4 F200 G90 G91 G1 H1 Z-265 F3600 ; move Z down until the endstop is triggered G90 ;G92 Z0 S1 ; set Z position to axis minimum (you may want to adjust this) G92 Z.03 ; absolute positioning ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position
I am sorry to bother you guys with so easy tasks, but before call for your help I have tried really hard for at least 8 hours trying to find the issue. I have read all your guidance in the Duet3D page and study the G code and M codes to understand my problem.
I have also reconfigured and uploaded the config files using the configtool for the reprap firmware that you have in your site for the Ender 3 but still not luck.
I hope you can help me
Thank you
Cheers
Javier -
@javcab Have you confirmed the z endstop is working correctly using M119?
@jay_s_uk Thanks for the reply
I have run the M119 and this is the result in the Console:M119
Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: at min stopStill the Z axis is not homing, when press the "Home All" the first to move is the Z axis 5mm up and then the Y and X homing correctly but never Homing the Z axis to the switch endstop.
@javcab said in Z Axis not homing endstops Ender 3:
if its saying at min stop and you don;t have the endstop triggered then its an issue with your wiring (assuming you're using the stock Ender 3 switch)
@jay_s_uk Hi thanks again for the reply.
I can check again the wiring, I have the original Ender 3 switches.
Before I have the IR Probe Z configured and I removed, after that I have this problem. Let me check and keep you posted.
@jay_s_uk You are an angel
Yes, the problem was one cable loose, I have pushed right in the mainboard and now Z is homing and all is good
Thank you
