Solved Duet 3 Mini 5+ WiFi not connecting properly
When I boot my Duet 3 Mini 5+ WiFi, it typically never connects to my network immediately. It will spam
16:24:49.156 -> WiFi reported error: network scan failed 16:24:49.156 -> WiFi module is idle
lots of times and then do either one of two things. The first thing it might do is have an
SPI timeout
:16:26:00.168 -> Error retrieving WiFi status message: SPI timeout 16:26:00.168 -> WiFi module is idle 16:26:00.349 -> Failed to change WiFi mode: SPI timeout 16:26:08.217 -> WiFi module is disabled
This requires me to enable the WiFi module again. Or, the second thing it will do (more frequently) is connect to a blank AP and have ip address
255.255.255.255
:16:26:18.009 -> WiFi module is connected to access point , IP address 255.255.255.255
From there, I put the WiFi module into
S0
and then back intoS1
to start the process all over again.When a network scan succeeds, I will see my network in the list, but there is sometimes these lines:
16:27:38.753 -> WiFi reported error: Unexpected WiFi state 'idle' while trying to connect to 16:27:38.753 -> WiFi module is idle 16:27:38.788 -> WiFi: ../src/SocketServer.cpp(357): found network 16:27:38.788 -> WiFi reported error: no known networks found
and it continues on and on. Then it does eventually connect to my network if on the current session it hasn't hit the
SPI timeout
or blank AP problem. On success I get it:16:28:29.298 -> WiFi: sleep enable,type: 2 16:28:29.756 -> WiFi: wifi evt: 2 16:28:31.469 -> WiFi: scandone 16:28:32.368 -> WiFi: state: 0 -> 2 (b0) 16:28:33.345 -> WiFi: state: 2 -> 0 (2) 16:28:33.345 -> WiFi: reconnect 16:28:33.345 -> WiFi: wifi evt: 1 16:28:33.345 -> WiFi: STA disconnect: 2 16:28:35.563 -> WiFi: scandone 16:28:35.563 -> WiFi: state: 0 -> 2 (b0) 16:28:35.563 -> WiFi: state: 2 -> 3 (0) 16:28:35.563 -> WiFi: state: 3 -> 5 (10) 16:28:35.563 -> WiFi: add 0 16:28:35.563 -> WiFi: aid 7 16:28:35.563 -> WiFi: cnt 16:28:35.563 -> WiFi: 16:28:35.597 -> WiFi: connected with mynetwork, channel 6 16:28:35.597 -> WiFi: dhcp client start... 16:28:35.597 -> WiFi: wifi evt: 0 16:28:35.633 -> WiFi module is connected to access point mynetwork, IP address 192.168.1.87 16:28:35.633 -> WiFi: ip:192.168.1.87,mask:255.255.255.0,gw:192.168.1.1 16:28:35.633 -> WiFi: wifi evt: 3
I've attached a session that shows all of the above (my AP is listed as
mynetwork
. Any ideas why this is happening?Edit: FYI my board came with 3.2 and this was happening, I've since upgraded to 3.3 and it is still happening.
Can you please post your config.g and the results of sending M122 and M98 P"config.g"?
Also send M587 by itself and see what SSIDs you have saved.
It may also be a good idea to send
M588 S"*"
to remove all saved networks and then re-add your preferred SSID with M587 again. -
I already cleared out the saved list of APs since my board came with one enabled already. Here is my current M587:
17:13:35.161 -> Remembered networks: 17:13:35.161 -> mynetwork IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0 17:13:35.161 -> ok
Here is the result of M112 while connected to the blank AP:
17:07:51.722 -> WiFi reported error: network scan failed 17:07:51.722 -> WiFi module is idle 17:07:51.722 -> WiFi reported error: network scan failed 17:07:51.722 -> WiFi module is idle 17:07:54.148 -> WiFi module is connected to access point , IP address 255.255.255.255 17:08:01.132 -> === Diagnostics === 17:08:01.132 -> RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode) 17:08:01.132 -> Board ID: DDHUY-P296U-D65J0-40KM8-LF03Z-7NL3U 17:08:01.132 -> Used output buffers: 1 of 40 (40 max) 17:08:01.132 -> === RTOS === 17:08:01.132 -> Static ram: 102724 17:08:01.132 -> Dynamic ram: 104928 of which 136 recycled 17:08:01.132 -> Never used RAM 35916, free system stack 160 words 17:08:01.132 -> Tasks: NETWORK(ready,12.6%,368) HEAT(delaying,0.0%,420) Move(notifyWait,0.1%,362) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,340) TMC(notifyWait,0.6%,115) MAIN(running,84.4%,578) IDLE(ready,1.5%,29) AIN(delaying,0.8%,273), total 100.0% 17:08:01.132 -> Owned mutexes: USB(MAIN) 17:08:01.132 -> === Platform === 17:08:01.132 -> Last reset 00:00:14 ago, cause: power up 17:08:01.132 -> Last software reset at 2021-07-07 15:08, reason: User, GCodes spinning, available RAM 35916, slot 0 17:08:01.132 -> Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a 17:08:01.132 -> Error status: 0x04 17:08:01.132 -> MCU revision 3, ADC conversions started 14945, completed 14944, timed out 0, errs 0 17:08:01.132 -> Step timer max interval 738 17:08:01.132 -> MCU temperature: min 23.9, current 27.2, max 27.2 17:08:01.132 -> Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes 17:08:01.132 -> Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 17:08:01.132 -> Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 753, writes 9, timeouts 0, DMA errors 0 17:08:01.132 -> Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 753, writes 9, timeouts 0, DMA errors 0 17:08:01.132 -> Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 753, writes 9, timeouts 0, DMA errors 0 17:08:01.132 -> Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 752, writes 9, timeouts 0, DMA errors 0 17:08:01.132 -> Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 753, writes 9, timeouts 0, DMA errors 0 17:08:01.132 -> Driver 5: position 0, assumed not present 17:08:01.132 -> Driver 6: position 0, assumed not present 17:08:01.132 -> Date/time: 1970-01-01 00:00:00 17:08:01.132 -> Cache data hit count 29034098 17:08:01.132 -> Slowest loop: 4.39ms; fastest: 0.11ms 17:08:01.132 -> === Storage === 17:08:01.132 -> Free file entries: 10 17:08:01.132 -> SD card 0 detected, interface speed: 22.5MBytes/sec 17:08:01.132 -> SD card longest read time 3.2ms, write time 0.0ms, max retries 0 17:08:01.132 -> === Move === 17:08:01.132 -> DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 17:08:01.132 -> === MainDDARing === 17:08:01.132 -> Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 17:08:01.132 -> === AuxDDARing === 17:08:01.132 -> Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 17:08:01.132 -> === Heat === 17:08:01.132 -> Bed heaters = -1 -1, chamberHeaters = -1 -1 17:08:01.132 -> === GCodes === 17:08:01.132 -> Segments left: 0 17:08:01.132 -> Movement lock held by null 17:08:01.132 -> HTTP is idle in state(s) 0 17:08:01.132 -> Telnet is idle in state(s) 0 17:08:01.132 -> File is idle in state(s) 0 17:08:01.132 -> USB is ready with "M122" in state(s) 0 17:08:01.132 -> Aux is idle in state(s) 0 17:08:01.132 -> Trigger is idle in state(s) 0 17:08:01.132 -> Queue is idle in state(s) 0 17:08:01.132 -> LCD is idle in state(s) 0 17:08:01.132 -> SBC is idle in state(s) 0 17:08:01.132 -> Daemon is idle in state(s) 0 17:08:01.132 -> Aux2 is idle in state(s) 0 17:08:01.132 -> Autopause is idle in state(s) 0 17:08:01.132 -> Code queue is empty. 17:08:01.132 -> === CAN === 17:08:01.132 -> Messages queued 74, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17), ts 74/0/0 17:08:01.132 -> Tx timeouts 0,0,73,0,0,0 last cancelled message type 30 dest 127 17:08:01.132 -> 17:08:01.132 -> === Network === 17:08:01.132 -> Slowest loop: 9.28ms; fastest: 0.00ms 17:08:01.132 -> Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions 17:08:01.132 -> HTTP sessions: 0 of 8 17:08:01.132 -> - WiFi - 17:08:01.132 -> Network state is active 17:08:01.132 -> WiFi module is connected to access point 17:08:01.132 -> Failed messages: pending 0, notready 0, noresp 0 17:08:01.132 -> WiFi firmware version 1.26 17:08:01.132 -> WiFi MAC address f0:08:d1:02:b5:d1 17:08:01.132 -> WiFi Vcc 3.32, reset reason Power up 17:08:01.132 -> WiFi flash size 2097152, free heap 25688 17:08:01.132 -> WiFi IP address 255.255.255.255 17:08:01.132 -> WiFi signal strength 31dBm, mode 802.11n, reconnections 0, sleep mode modem 17:08:01.132 -> Clock register 00002002 17:08:01.132 -> Socket states: 0 0 0 0 0 0 0 0 17:08:01.132 -> ok
and same for
M98 P"config.g"
:17:09:10.052 -> HTTP is enabled on port 80 17:09:10.052 -> FTP is disabled 17:09:10.052 -> TELNET is disabled 17:09:10.052 -> ok
Here is my
config.g
:; General G90 ; send absolute coordinates... M550 P"MPCNC" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet M453 ; Enable CNC mode ; Drives M569 P0 S1 ; X0 M569 P1 S0 ; X1 M569 P2 S0 ; Y0 M569 P3 S1 ; Y1 M569 P4 S0 ; Z M584 X0:1 Y2:3 Z4 U0 V1 A2 B3 R0 P3 ; R0 = assume linear, P3 = 3 axes visible M350 X256 Y256 Z256 U256 V256 A256 B256 I0 ; configure microstepping with interpolation ; calculator: https://blog.prusaprinters.org/calculator_3416 ; belt pitch 2 mm / pulley teeth 16 ; 256x: 6.25*256=1600 for belts (X and Y) ; Lead screw T8 4 start 2mm pitch, 8mm/rev -- 25*256=6400 M92 X1600 Y1600 Z6400 U1600 V1600 A1600 B1600 ; set steps per mm M566 X900 Y900 Z60 U900 V900 A900 B900 ; set maximum instantaneous speed changes (mm/min) M203 X6000 Y6000 Z180 U6000 V6000 A6000 B6000 ; set maximum speeds (mm/min) M201 X500 Y500 Z20 U500 V500 A500 B500 ; set accelerations (mm/s^2) M906 X1500 Y1500 Z1500 U1500 V1500 A1500 B1500 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; set idle timeout ; Setup dimensions are 24 in x 18 x 3.25 in, but actual dimensions are measured below ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X600 Y440 Z82 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io0.in+io1.in" M574 Y1 S1 P"io2.in+io3.in" ; Z-Probe M558 K0 P5 C"^!io4.in" H5 F100 T6000 ; set Z probe 0 to digital switch type, invert and enable pullup resistor G31 P900 X0 Y0 Z0.5 ; set Z probe trigger value, offset and trigger height ;M557 X15:215 Y15:195 S20 ; define mesh grid ; Heaters M140 H-1 ; disable heated bed (overrides default heater mapping)
Here is M122 when connected to my access point:
17:12:15.939 -> WiFi module is connected to access point mynetwork, IP address 192.168.1.87 17:12:27.077 -> === Diagnostics === 17:12:27.077 -> RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode) 17:12:27.077 -> Board ID: DDHUY-P296U-D65J0-40KM8-LF03Z-7NL3U 17:12:27.077 -> Used output buffers: 1 of 40 (11 max) 17:12:27.077 -> === RTOS === 17:12:27.077 -> Static ram: 102724 17:12:27.077 -> Dynamic ram: 104928 of which 136 recycled 17:12:27.077 -> Never used RAM 35916, free system stack 150 words 17:12:27.077 -> Tasks: NETWORK(ready,11.9%,264) HEAT(delaying,0.0%,420) Move(notifyWait,0.1%,362) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,340) TMC(notifyWait,0.7%,115) MAIN(running,85.9%,592) IDLE(ready,0.7%,29) AIN(delaying,0.8%,273), total 100.0% 17:12:27.077 -> Owned mutexes: USB(MAIN) 17:12:27.077 -> === Platform === 17:12:27.077 -> Last reset 00:00:31 ago, cause: software 17:12:27.077 -> Last software reset time unknown, reason: HardFault invState, GCodes spinning, available RAM 35916, slot 2 17:12:27.077 -> Software reset code 0x0063 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x0041e803 BFAR 0xe000ed38 SP 0x20011e50 Task TMC Freestk 127 ok 17:12:27.077 -> Stack: 200190b0 20011bfc 20001064 e000e000 00000060 00089625 00000000 60000000 00000001 00000000 200117b0 0002cab3 00000004 00000003 200117b0 20011bf4 00000004 41008000 a5a5a5a5 0002cbdb a5a5a5a5 00087e75 a5a5a5a5 00000000 846f0005 c06fff05 9b00000e 17:12:27.077 -> Error status: 0x00 17:12:27.077 -> MCU revision 3, ADC conversions started 31391, completed 31390, timed out 0, errs 0 17:12:27.077 -> Step timer max interval 751 17:12:27.077 -> MCU temperature: min 31.6, current 32.6, max 32.6 17:12:27.077 -> Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 17:12:27.077 -> Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 17:12:27.077 -> Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 31, reads 1613, writes 9, timeouts 0, DMA errors 0 17:12:27.077 -> Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 31, reads 1613, writes 9, timeouts 0, DMA errors 0 17:12:27.077 -> Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 31, reads 1613, writes 9, timeouts 0, DMA errors 0 17:12:27.077 -> Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 31, reads 1612, writes 9, timeouts 0, DMA errors 0 17:12:27.077 -> Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 31, reads 1613, writes 9, timeouts 0, DMA errors 0 17:12:27.077 -> Driver 5: position 0, assumed not present 17:12:27.077 -> Driver 6: position 0, assumed not present 17:12:27.077 -> Date/time: 2021-07-07 17:12:25 17:12:27.077 -> Cache data hit count 60684450 17:12:27.077 -> Slowest loop: 4.35ms; fastest: 0.11ms 17:12:27.077 -> === Storage === 17:12:27.077 -> Free file entries: 10 17:12:27.077 -> SD card 0 detected, interface speed: 22.5MBytes/sec 17:12:27.077 -> SD card longest read time 3.2ms, write time 0.0ms, max retries 0 17:12:27.077 -> === Move === 17:12:27.077 -> DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 17:12:27.077 -> === MainDDARing === 17:12:27.077 -> Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 17:12:27.077 -> === AuxDDARing === 17:12:27.077 -> Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 17:12:27.077 -> === Heat === 17:12:27.077 -> Bed heaters = -1 -1, chamberHeaters = -1 -1 17:12:27.077 -> === GCodes === 17:12:27.077 -> Segments left: 0 17:12:27.077 -> Movement lock held by null 17:12:27.077 -> HTTP is idle in state(s) 0 17:12:27.077 -> Telnet is idle in state(s) 0 17:12:27.077 -> File is idle in state(s) 0 17:12:27.077 -> USB is ready with "M122" in state(s) 0 17:12:27.077 -> Aux is idle in state(s) 0 17:12:27.077 -> Trigger is idle in state(s) 0 17:12:27.077 -> Queue is idle in state(s) 0 17:12:27.077 -> LCD is idle in state(s) 0 17:12:27.077 -> SBC is idle in state(s) 0 17:12:27.077 -> Daemon is idle in state(s) 0 17:12:27.077 -> Aux2 is idle in state(s) 0 17:12:27.077 -> Autopause is idle in state(s) 0 17:12:27.077 -> Code queue is empty. 17:12:27.077 -> === CAN === 17:12:27.077 -> Messages queued 156, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17), ts 156/0/0 17:12:27.077 -> Tx timeouts 0,0,155,0,0,0 last cancelled message type 30 dest 127 17:12:27.077 -> 17:12:27.077 -> === Network === 17:12:27.077 -> Slowest loop: 11.39ms; fastest: 0.00ms 17:12:27.077 -> Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions 17:12:27.077 -> HTTP sessions: 1 of 8 17:12:27.077 -> - WiFi - 17:12:27.077 -> Network state is active 17:12:27.077 -> WiFi module is connected to access point 17:12:27.077 -> Failed messages: pending 0, notready 0, noresp 0 17:12:27.077 -> WiFi firmware version 1.26 17:12:27.077 -> WiFi MAC address f0:08:d1:02:b5:d1 17:12:27.077 -> WiFi Vcc 3.31, reset reason Power up 17:12:27.077 -> WiFi flash size 2097152, free heap 25016 17:12:27.077 -> WiFi IP address 192.168.1.87 17:12:27.077 -> WiFi signal strength -75dBm, mode 802.11n, reconnections 0, sleep mode modem 17:12:27.077 -> Clock register 00002002 17:12:27.077 -> Socket states: 0 0 0 0 0 0 0 0 17:12:27.077 -> ok
Your wifi signal strength when connected is borderline. If there is no wifi access point within range it may be causing it to default to the 255.255.255.255 network while it rescans.
How far are you from your access point?
@phaedrux About 30 ft. But when I was putting this together, I was in the same room as the AP and this still occurred.
Here's what I would try.
Double check that the wifi antenna is connected to the module correctly and not damaged. It's a delicate plug.
Send
M997 S1
to reflash the wifi module firmwareSend
M588 S"*"
to erase all saved SSIDsRe add the SSID with M587 again.
If it's still not connecting, test again closer to the AP. If it's still not connecting, then we'd start suspecting hardware failure and warranty replacement.
I think I now recall not wiping all saved SSIDs. I think I just removed the extra one that was showing up. Before upgrading the firmware (since I just upgraded to 3.3 the other day), I decided to see if just erasing the SSIDs would fix it. And it did!
I no longer get any of the error message spam, no more timeouts or blank AP connections and after boot it connects right away to my regular AP. I did this about 10 times in a row with success.
Thanks for your help!
