    Part Cooling Fan + Berd Air config
    Gcode meta commands
    1
    1
    74
    • djarmag
      djarmag last edited by
      I have a Rostock V3 with Duet Wifi installed and I am having difficulty setting a part cooling fan to turn on 100% when my Berd Air pump turns on. This is what I have so far, I disabled thermostatic mode and force the part cooling fans to turn off (they turn fully on when turning on machine power)
      My Berd Air is set properly and turns on to whatever I set in my slicer and it changes speed properly.
      My goal is to turn on my part cooling fans 100% only when Berd Air pump is running. I also do not want the part cooling fans to change speed which is why I'm trying to set it somewhat independent from the Berd air. Can anyone help please?
      M106 P1 H-1 ; disable thermostatic mode for fan 1
      M106 P1 S0
      M106 P1 X1 ; set max fan speed when non-zero fan speed is requested
      ; Tool definitions
      M563 P0 D0 H1 ; Define tool 0
      G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
      ;*** If you have a single-nozzle build, comment the next 2 lines
      ;M563 P1 D1 H2 ; Define tool 1
      ;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
