New test firmware 1.19+5
Hello everyone
David I made an impression of 2h in 1.19 + 6, and apparently more problem of vibration in me.
On the other hand I still had a disconnection of the card on the web, I try on 2 computers, and impossible to reconnect.
I do not know if this comes from my network or update.
thank you for your work -
Thank for your message. Please clarify:
1. Is vibration still a problem for you, or not?
2. If vibration is still a problem, does it occur at any particular place in the print? For example, when printing the skirt of a print that was sliced using Simplify3D.
Regarding the network disconnection:
1. Did you install version 1.19+1 of the wifi module firmware (DuetWiFiServer.bin)? The Settings/General page of Duet Web Control will tell you which version of the WiFi Server you are running.
2. If yes, then any reconnection attempts made will be reported to PanelDue if you have one (check the Console page) and to USB.
1> I no longer have any vibration.
Ā Network
1> Yes I'm fine with WiFi Server Version: 1.19 + 1
2> I would look next time that this product and I would tell you. -
apparently 1.19+6 ok for me no vibrate on my Scara, Thanks
I feel that the speed is faster ? -
Thanks, both of you. I'll relabel 1.19+6 as 1.19.2 and release it later this afternoon.
