Tool not showing DWC
I updated my firmware and now my extruder tool isn't showing in the DWC or my panel. Only the heated bed is showing.
Here is my config. Would appreciate any help. I'm sure I probably overlooked something simple.
; generated by RepRap ver v3.2.3 on Wed Jul 21 2021 15:54:12 GMT-0400 (Eastern Daylight Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 P">>> Duetmaker <<<" ; Set machine name
M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0.0 S0 ; physical drive 0.0 goes forwards
M569 P0.1 S0 ; physical drive 0.1 goes forwards
M569 P0.2 S0 ; physical drive 0.2 goes forwards
M569 P0.3 S1 ; physical drive 0.3 goes forwards
M92 X80.00 Y80.00 Z400.00 E415 ; set steps per mm
M203 X18000 Y18000 Z2400 E2700 ; Set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z500.00 E250.00 ; set accelerations (mm/s^2)
M906 X1200 Y1200 Z1200 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X225 Y220 Z305 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!io4.in" ; configure active-high endstop for low end on X via pin io0.in
M574 Y1 S1 P"!io3.in" ; configure active-high endstop for high end on Y via pin io1.in
M574 Z2 S1 P"!io1.in" ; configure active-high endstop for high end on Z via pin io2.in; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:210 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M950 F0 C"out2" Q500 ; create fan 0 on pin out2 and set its frequency
M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M563 P0 S"Extruder" D1 H1 F0 ; define tool 0
G10 P0 R0 S0
; Custom settings are not defined; Miscellaneous
M575 P1 S1 B57600 ; enable support for PanelDue; Custom settings are not defined
M575 P1 S1 B57600 ; enable support for PanelDue -
When upgrading firmware, always read the upgrade notes.
If you run this command:
M98 P"config.g"
then you should see an error message telling you why the tool was not created.
